Homemade soektrum bind plug
Can a person make a homemade bind plug have read you can any help would be useful.
If you have an old broken servo or a bad receiver battery with a futaba/JR plug cut off the wire and connect the outside wires together and leave the middle one alone. In case of a Futaba plug, connect the white with the black.
I have plug from losi ten t that is no good wires are black red and orange
I've use tweezers, or paperclip already when in a pinch. Steady hand to connect the signal and negative post is all you need.
https://cimg8.ibsrv.net/gimg/www.rct...929a3966bc.jpg |
| All times are GMT -7. It is currently 06:22 PM. |
