Sanwa M17- New TOTL Pistol >
Like Tree277Likes
Old 05-18-2019, 12:10 PM
  #1036
Originally Posted by mvert View Post
Please, help needed !
I cannot bind my M17 transmitter with my RX491 receiver.
I'm following the procedure : led of the receiver is rapidly flashing when it is connected with the transmitter on bind mode selection, but even after 5 minutes, the light of the receiver never get glows and bind is not done.
I tried several time but still the same..
Receiver connection :
CH1 : steering
CH2 : ESC
SSL : bing plug
Transmitter selection :
RF Mode : FH5
Response mode : SHR (with a SRT BH9027 servo)
Is there something I have missed or doing wrong ?
Thank you for your help.
You missed the last step. You still need to hit the bind button on the radio again to finalize the bind. Once done the receiver led will be solid.
Garet Jax likes this.
trigger is offline
Old 05-19-2019, 06:04 PM
  #1037
Garet Jax's Avatar
Trader Rating: 95 (100%+)
The M17 foam arrived today and it is a pretty perfect fit. I used the top foam included with the case (removed the backing) and the bottom foam for the M17.
I might need to cut out a little bit of the radio shaped foam since the Vault's bottom is just plastic and I don't want the radio bouncing against the plastic.
Garet Jax is offline
Old 05-20-2019, 03:51 PM
  #1038
rcfiend's Avatar
Trader Rating: 37 (100%+)
Just received my radio and the ribbon connector from the wheel to the radio was broken. Does anyone know if the M12 ribbon is the same as the M17?
rcfiend is offline
Old 05-21-2019, 04:45 PM
  #1039
Garet Jax's Avatar
GrandeGixxer and scott_0 like this.
Old 05-21-2019, 06:19 PM
  #1040
Has anyone tried to use the protek black label servos in sur mode?
jdsand5 is offline
Old 05-22-2019, 09:51 AM
  #1041
fergraz is offline
Old 05-22-2019, 06:21 PM
  #1042
Trader Rating: 22 (100%+)
I tried. It doesn't respond.
NoobRacer is offline
Old 05-22-2019, 06:26 PM
  #1043
CH1 : steering
CH2 : ESC
SSL : bing plug
RF Mode : FH5
You need to remove the bind jumper to finish.
fergraz is offline
Old 05-23-2019, 09:02 AM
  #1044
dickie doyle's Avatar
Muchmore lists a big lipo for M17. Anyone know if the usb charger would work?
dickie doyle is offline
Old 05-23-2019, 02:59 PM
  #1045
Ice_nl's Avatar
No, the charger is build into the Sanwa battery:
Ice_nl is offline
Old 05-24-2019, 07:45 PM
  #1046
Garet Jax's Avatar
Thanks for letting us know. I "assumed" the recharging capability was in the radio and not the battery. None of the replacement batteries that I have seen mention this. Do you know if there is a place to purchase a Sanwa LP1-2500 (the actual replacement battery)?
Old 05-25-2019, 03:58 AM
  #1047
Trader Rating: 14 (100%+)
I just upgraded from a DX3R and have 3-4 primary vehicles I'll be using. Is it worth splurging for the latest 491 receiver or is the 481 close enough performance wise? All vehicles are electric
Double D Donuts is offline
Old 05-25-2019, 02:43 PM
  #1048
I was thiiiiiiiiiis close lol to buying one of these today at the track, just couldn't do it, I need to buy another receiver and it gets pricey at that point, thinking I'll just grab the 7px since I already have Futaba receivers
scott_0 is offline
Old 05-25-2019, 03:10 PM
  #1049
With the price difference from the Futaba 7PK to the Sanwa M17 you can buy 2 extra receivers for the Sanwa M17.
fergraz is offline
Old 05-25-2019, 04:43 PM
  #1050
maybe I'm wrong on the price, I'll have to go back and research it, thanks!
scott_0 is offline
