Sanwa M17- New TOTL Pistol >
Like Tree284Likes
Old 05-15-2019, 08:32 AM
  #1021
Originally Posted by EbbTide View Post
Yes there is a small pad with a wire that attaches to the battery inside. And that small pad contains the coil that allows it to wirelessly charge.
everything fits inside the battery compartment ok?
RookieRacer00 is offline
Old 05-15-2019, 08:51 AM
  #1022
EbbTide's Avatar
Trader Rating: 39 (100%+)
that I don't know. I won't be getting one of these radios. I'm hoping for something in the mt-44 price range. I assume it does considering the above user made it work.
EbbTide is offline
Old 05-15-2019, 09:43 AM
  #1023
Garet Jax's Avatar
Trader Rating: 96 (100%+)
OK guys. With the $90 coupon from Tower, the 7px is within $100 of the M17. I am leaning towards the M17 just because it is newer, but wanted other opinions. Which would you choose?
Garet Jax is offline
Old 05-15-2019, 01:15 PM
  #1024
1/8 IC Fan's Avatar
Trader Rating: 91 (100%+)
Originally Posted by Garet Jax View Post
Can you folks please help me understand how the radio + receiver + ESC + Servo work together? I am coming from Nitro so the servo was used just to control steering and braking.
I bought a used Tekno EB410 that already comes with a servo, an ESC and a motor - none are Sanwa. I have an M17 and will be using the receiver that came with it (RX-491). What are the things I won't be able to do since the ESC and the servo aren't from Sanwa?
If I was to change the ESC and the Servo to maximize the radio's functionality, would I have to buy Sanwa products or are there other products that I could use?
Thanks.
You already have an M17 I see, how does it feel?
1/8 IC Fan is offline
Old 05-15-2019, 03:41 PM
  #1025
Garet Jax's Avatar
Originally Posted by scott_0 View Post
you can use any esc you choose, there is a calibration process for each esc to your radio, it is simple to do and will be covered in the esc instructions. what brand esc is in the buggy?
It is a hobbywing XR10
Old 05-15-2019, 05:17 PM
  #1026
Sanwa receivers are smaller
Bubonic-X is offline
Old 05-15-2019, 05:38 PM
  #1027
Sanwa is faster.
Cardiak is offline
Old 05-15-2019, 06:17 PM
  #1028
Garet Jax's Avatar
Don't have it quite yet. It's coming from AMains (slowly) and I can still return it for a full refund.
Old 05-15-2019, 08:55 PM
  #1029
wrightcs77's Avatar
Trader Rating: 543 (100%+)
Are Sanwa receiver cases still very brittle? They always seem to crack . I have had them crack from pulling them off the chassis to sell them? That is the main reason I switched from Airtronics two years ago.
wrightcs77 is offline
Old 05-15-2019, 10:37 PM
  #1030
Trader Rating: 17 (100%+)
Is the m17 in ssr mode with a Sanwa servo faster than the 7px in sr mode with a Futaba sr compatible servo?
riceball777 is offline
Old 05-16-2019, 04:52 AM
  #1031
1/8 IC Fan's Avatar
The 482 is a bit fragile (compared to a Futaba receiver) , but I learned using two small 3M strips at the ends vs, the entire length of the receive bottom, allows for easier removal and less chance of damaging it. But in all they have held up in TC, F1, 1/8 Nitro Buggy and 1/8 IC.
Old 05-16-2019, 01:59 PM
  #1032
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
I run a strip of strapping tape around the seam as soon as I get them.
GrandeGixxer is offline
Old 05-17-2019, 10:55 AM
  #1033
Garet Jax's Avatar
Originally Posted by trigger View Post
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Wireless charging can be done for less than 20 bucks!
I went with this one below because of the bigger pad.
Trigger,
It's hard to tell from the pictures. Does the Qi Wireless Charging Receiver fit inside the base or does it have to stay on the outside?
Old 05-17-2019, 05:34 PM
  #1034
Garet Jax's Avatar
Originally Posted by Motorman007 View Post
Which Pelican case? Drone 1 or gun?
I bought this one. Its measurements seemed to fit the M17 foam and the price was right. I bought this one. Its measurements seemed to fit the M17 foam and the price was right.
Motorman007 likes this.
Old 05-18-2019, 11:08 AM
  #1035
Please, help needed !
I cannot bind my M17 transmitter with my RX491 receiver.
I'm following the procedure : led of the receiver is rapidly flashing when it is connected with the transmitter on bind mode selection, but even after 5 minutes, the light of the receiver never get glows and bind is not done.
I tried several time but still the same..
Receiver connection :
CH1 : steering
CH2 : ESC
SSL : bing plug
Transmitter selection :
RF Mode : FH5
Response mode : SHR (with a SRT BH9027 servo)
Is there something I have missed or doing wrong ?
Thank you for your help.
mvert is offline
