Sanwa M17- New TOTL Pistol
#287
Info about the raido>
Credit: www.mibosport.com/Michal Bok
Annoucement about Sanwa M17
24 Aug 2018News
According to multiplying queries about new Sanwa M17 transmitters, which is already available on Asian market, we would like to calm you down and bring things to the right. M17 now available on Asian market is special Japanese version, which doesn’t have a lot of features in compare with EU / Worldwide version. No worries, nobody have full EU / Worldwide version yet.
Thank you for understanding
Michal Bok
Features which Japanese / Asian version doesn’t have and EU / Worldwide version will:
1. SERVO MONITOR DISPLAY
Some graph and bar in setting menu is not available for JP version.
2. SYNC-START FUNCTION is not available for JP version.
3. R-MODE FUNCTION is not available for JP version.
4. FUNCTION TH RATE in TELEMETRY SWITCH Function
TH rate can be set but it does not work for JP version.
5. RX-MODE-SETTING Function is not available for JP version
Display RX-MODE-SETTING function but it cannot set.
M17 will be telemetry logger by using telemetry function to combine with compatible receiver.
※It is different RF MODE to change output FH system.
6. KEY-ASSIGN SW
C-MIX 1~5 for SW3 can display but did not work for JP version.
Also, it cannot set <ALTERNATE>
7. Below Function in KEY-ASSIGN TRIM
<CM*-*/AUX*-FLAP,TH-FL/OFFSET-SW/INT*-SW/CUSTOM/DOWN-SW/VOICE-REQ/SELECT/INC DEC> cannot be assign in TRIM1~TRIM5,DIAL
8. AUX TYPE(CODE10-GEN2/PGS)
CODE10 can be used by M17. Mode is only USER is available.
9. LCD LIGHT-MODE KEY-ON
LCD LIGHT cannot set KEY-ON function for JP version.
10. TOUCH PAD Function (Only Default)
It cannot change setting for JP version.
11. User name on opening picture
It can be set user name but the user name does not display on the opening picture for JP version.
24 Aug 2018News
Michal Bok
6. KEY-ASSIGN SW
#288
Well that kinda stinks do you mind posting some videos or anything like that
#289
does it have a drop down?
#297
Thank you for posting the video, Nice seeing the remote in action. The menu and touchpad is a bit of a let down but if the radio feels nice and drives awesome I guess you can look past it.
#298
#299
the drop down seems easier to apply than m12s, thanks for the pictures!
#300
Does the radio/RX hve a ABS function?
