LRP Stock Spec ESC
I have a problem with my LRP Stock Spec V2 ESC. I can set the ESC but the motor does not turn. Get the error code #2 (Mode LED = Red, Set LED = flashing blue), so it appears to be a Motor Thermal Shutdown. What do you need to do to resolve this issue?
Your help is greatly appreciated. Please reply to [email protected] |
What motor and did you try a different sensor cable yet?
Tried different motor that I knew worked as well as a different sensor cable.....
I think I need to reset the Motor thermal Shutdown somehow..... as that is what the error code is. |
Originally Posted by getherdone
(Post 15182588)
Andy, thanks for the suggestion, but even after resetting to defaults, the error still occurs.
Unfortunately, I have two of these ESC's, neither of which work and LRP is shutting down...... |
(Post 15184489)
| All times are GMT -7. It is currently 09:27 AM. |
