-   -   Wire gauge and amperage... (https://www.rctech.net/forum/radio-electronics/1009986-wire-gauge-amperage.html)
rhcustoms 02-07-2018 07:43 AM
Is there a chart that the shows how many amps a a wire gauge can handle or website?
Darkgenerals 02-07-2018 07:50 AM
So Google was to hard to type that into?
Edit: before you say I'm being mean and rude, you took no effort to Google before posting a question, i will put no effort as well.
the rc guy 02-07-2018 07:51 AM
many to many to list...https://www.google.com/search?q=wire...ih=434#imgrc=_
rhcustoms 02-07-2018 07:56 AM
Thank you, the rc guy, that helps a ton.
platgof 02-10-2018 05:55 PM
I find that certain batteries demand certain wires. If the battery has a high draw then one must use a larger wire. When I run a 4x4 sct 2s that draws a lot of juice, then I use a 10 gauge wire to the esc. On 3 and 4 s systems I also use a 10 gauge wire to the esc. Because a motor uses 3 wires from the esc, the load is much easier, and 12 gauge usually suffices.
