Discharge bank?
Hi all, I currently use a Ultrapower UP100 duo charger. I replaced a more powerful, but MUCH larger charger with this and am happy with it except for one thing- the discharge power is so low that it takes forever to set a pack for storage after a stock race. Is there a way to get/make a discharge bank to pull more amps? Not looking for a 40a rate, I'd be happy with 5a.
12v light bulb... if i remember correct each 1157 bulb using both elements is about 2.1 amps draw so to get 5 amps ull need like 3 bulbs..there are still reactor dischargers on the market from 10/15/20/30 amps..simple adjust the internal pot on back side of board to get it to correct voltage of 7.85 to 7.65.. there was a step by step how to do this by drilling hole in front totally wrong info.. its on the back facing board not front facing..its by some one called jimmy..https://www.tqrcracing.com/shop/prod...ALw_wcB#images
with a amp meter you can check how many amps the bulbs will be drawing.. there will be a slight increase in amps as bulbs get hotter.. i installed a fan on mine that runs off of main power plug. |
| All times are GMT -7. It is currently 10:43 PM. |
