Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree6Likes
Old 01-08-2018, 05:52 PM   #1
Default How do I know when Battery is fully charged see pic
Question in heading..picture tells all I think?
So when is it fully charged.
I have it set to lipo balance
NitroB810 is offline   Reply With Quote
Old 01-08-2018, 05:54 PM   #2
EbbTide's Avatar
Trader Rating: 35 (100%+)
usually the charger notifies you with a chime or beeps. The end voltage should be 4.2v per cell or 8.4v total for 2s lipo.
:::Tekno EB410::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210v3 :::Tamiya TB03r/TRF418-ish :::
EbbTide is online now   Reply With Quote
Old 01-08-2018, 05:57 PM   #3
Ill keep an eye on it and see, it started on 7.2v but I know the battery was empty is that correct?. Thank you.
Old 01-08-2018, 05:59 PM   #4
EbbTide's Avatar
It depends on what your ESC has its lipo cutoff set at. If it's at 7.2v then I imagine your lipo cutoff is set for 3.6v per cell which is conservative but not a bad thing.
Old 01-08-2018, 06:00 PM   #5
The battery should not have been empty. Instead it should be stored with a storage charge which is why it was at 7.2V. That charger has a setting for storage charge.
faqcya is offline   Reply With Quote
Old 01-08-2018, 06:57 PM   #6
Trader Rating: 217 (100%+)
Charging at 2 amps is gonna take a long time (couple hrs.) and if the battery was empty, it's probably no good. Shouldn't be drained below 3.0 volts per cell. 6 volts for a 2 cell.
Andy Koback is offline   Reply With Quote
Old 01-09-2018, 06:09 AM   #7
olds45512's Avatar
Since your battery is 3200mah you should be balance charging it at 3.2amp. whenever you balance charge you want to do it at 1x the capacity so it you have a 4400mah pack you would charge at 4.4amp and if it's 5000mah you would charge at 5.0amp.
2fst4u67 and NitroB810 like this.
FRIENDS DON'T LET FRIENDS RACE OVAL
olds45512 is online now   Reply With Quote
Old 01-09-2018, 07:31 AM   #8
Press the second button from right to see each cell's level. 4.20v = full
You should use a lipo safety bag.
NitroB810 likes this.
D1360 is offline   Reply With Quote
Old 01-09-2018, 07:49 AM   #9
Im assuming that charger is just like all the other budget 4 button chargers....it will start beeping when its finished charging. Loud annoying beeping lol
WdotDynamite is offline   Reply With Quote
Old 01-09-2018, 12:16 PM   #10
This charger cannot always decide when the battery is fully loaded. The battery can have 4.2/cell, but the charger continues the balancing. Therefore he must check status of each cell instead.
Old 01-10-2018, 10:32 AM   #11
Many chargers allow you to set the capacity of the battery you are charging so you don't over charge it. Check to see if that feature is available.
DoubleRR24 is offline   Reply With Quote
Old 01-11-2018, 09:37 AM   #12
Slashracer1998's Avatar
That specific charger will say "Done" or "Full" where it shows Li2S in the photo and it will show 0.0A right next to the "done"
3 Traxxas Slash 2wd, Sc10 2wd, Team Associated rc10l oval, Silva Concepts X-Factor, Maverick '04 chassis, F-14 Tomcat, F-14 Classic, Traxxas Stampede 2wd, Tamiya TT02D, Losi Mini Late Model
------------------------------------------------------------------------------CHECK-IT RACING------------------------------------------------------------------------------
Slashracer1998 is offline   Reply With Quote
Old 01-13-2018, 12:50 AM   #13
dan_vector's Avatar
Trader Rating: 27 (100%+)
Do yourself a favour and use a lipo charging safety bag to avoid burning your house down when using cheap chargers and batteries.
Next read the manual for the charger as that'll be a big clue as to what to expect during the charge cycle. As others have said the charger will follow the settings you have selected or its defaults (read the manual) and declare it has finished charging usually at 4.20 v per cell.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-13-2018, 05:17 AM   #14
Old 01-13-2018, 05:33 AM   #15
Thanks guys for your help.
It beeps when full and also max charge per cell is to be 4.2 as you have mentioned so max 8.4 for 2s battery - 16.8v max for a 14.8v 4s battery etc.
Should the storage charge per cell be about 3.8v?
Small Lipo Puff Testing... HappyGene Radio and Electronics 6 10-30-2015 09:29 AM
Sellers: BEWARE of "M3ROC" TimNJ Buyer/Seller dispute and Feedback discussion forum 93 04-20-2013 07:29 PM
2011/2012 WCICS Official Thread IronRing Racing Canadian R/C Scene 732 04-18-2012 09:33 PM
3000ft my ass.... Mugen MBX-5 Nitro Off-Road 57 04-03-2008 08:31 PM
