-   -   4PLS vs 4PV vs 4PX (https://www.rctech.net/forum/radio-electronics/1004847-4pls-vs-4pv-vs-4px.html)
Rcracing01 12-09-2017 04:25 AM
4PLS vs 4PV vs 4PX
Hello all,
Trying to determine which is the best bang for your buck. Clearly the PX has the most options but I don’t think I would use all in TC racing.
Any thoughts on comparison?
Roelof 12-09-2017 04:48 AM
4pls and 4PX, looking to functionality the 4PX does support FASST receivers but beside that the 4PLS has all the functions you need.
So far I can see the 4PV has less functionality compared with the 4PLS like no telemetry logging but still all the functionality to drive and setup a car.
chevmaro 12-09-2017 07:46 PM
Originally Posted by Rcracing01 (Post 15099203)
Hello all,
I bought a 4PV yesterday. I held one at the track, felt good in my hand, looked good and was the right price. I am replacing a M11X. I hope this is a suitable replacement as the M11X was high end back when it came out.
Rcracing01 12-09-2017 08:22 PM
Good to hear because I was leaning to the 4PLS new or a 4PX used.
Thank you for the feedback
1/8 IC Fan 12-09-2017 08:24 PM
Even a used 4PLS will be a great radio, I am on my third 4PLS. This way you can get used to the Futaba layout and setup, then perhaps go from there.
tobyzhang 12-09-2017 11:43 PM
I'm pretty sure 4PV is meant to be a replacement of the 4PLS. It retains all of the functionality and adds a drop down conversion. 4PV ergonomics is more similar to 4PX while 4PLS is more similar to 4PKS, in terms of wheel feel and trigger feel. Overall 4PLS is a more refined system that uses the same receivers as 4PLS.
JPAPA26 12-10-2017 06:14 PM
I been using the 4pls for awhile an have had great luck with it. I have 6 different models programmed and find it easy to swap model to model. Adjustments on the fly are easy and the backlight is a nice feature.
Plus used u can grab them pretty cheap just watch out the antenna’s seem to break easily
STLNLST 12-10-2017 09:59 PM
May want to check Futaba's website or A-main for feature's as some mis information may have been stated earlier.
Bubonic-X 12-13-2017 04:12 PM
Will the 4pv work with the R203GF and the R204GF-E receivers?
1/8 IC Fan 12-13-2017 04:33 PM
Check here:
https://www.futabarc.com/receivers/f...ss-compat.html
