-   -   Toro 1s...Blinky? (https://www.rctech.net/forum/radio-electronics/1003931-toro-1s-blinky.html)
Farmer_John 11-28-2017 06:44 PM
Toro 1s...Blinky?
It’s mentioned in the owners manual, but nowhere in the setup sheet or a choice within the programming box.
Am I tilting at windmills with this ESC trying to find a Blinky mode?
I’m sure there’s gotta be some knowledge out there. Thanks.
howardcano 11-28-2017 06:50 PM
If it is the 1S120, then check the ROAR list:
ROAR Racing
"Red LED, .19 seconds/flash. Non-Timing: Use program box to set boost timing and Turbo timing to zero."
Farmer_John 11-28-2017 10:51 PM
It is indeed a 1s120 and thanks. I had thought I had done those setting changes, but I'll look again.
1/8 pan car, eh? We're running them again in Toledo, Chicagoland, Cincinnati and a few other US locations...
howardcano 11-29-2017 08:34 AM
Some programming boxes make changes to the ESC immediately (when you change a value), while others require a separate action to save all changes made in the current session to the ESC. I don't recall what the Toro does, but it's always good to double-check.
I had considered making some road trips to your neck of the woods to run my old RC300 again (and I even bought a new engine for it), but life has gone a different direction for me, making travel difficult.
