-   -   Trinity Monster 13.5 - Tuning help (https://www.rctech.net/forum/radio-electronics/1003413-trinity-monster-13-5-tuning-help.html)
EricW 11-23-2017 11:06 AM
Can someone give me some tuning tips on this motor? I'm not sure if this is just a weaker motor compared to other 13.5s out there but I'm getting walked by other cars at the track. I'm using it in my XB4 in 13.5 blinky.
Have it geared 78x25, end bell timing is 49 degrees. I have a motor checker so I can check the amp draw but I just don't know what's a good target for amp draw on a 13.5
Thanks.
billdelong 11-24-2017 06:54 AM
Not familiar with the FDR in the XB4, but I'm running that same motor in my Tekno EB410 with 24/81 gearing and it's by far the fastest car at my club... guys with the Tekin Spec-R motors aren't happy and are saying I must be cheating, ha! I bought mine from Team Eric Anderson Motorsports, so it's not certified, but Eric tuned the motor for me so I can't say exactly what the timing is set to, but it kinda looks close to 46°-47° if I had to guess:
https://c1.staticflickr.com/5/4552/2...db071291_c.jpg
*** It's also worth noting that I noticed my fast lap time increased 0.4 sec this past week, so I rebuilt the car and found a crunchy bearing that needed to be replaced, hopefully I get that time back next race day ;)
EricW 11-24-2017 06:57 AM
Originally Posted by billdelong (Post 15086393)
Not familiar with the FDR in the XB4, but I'm running that same motor in my Tekno EB410 with 24/81 gearing and it's by far the fastest car at my club... guys with the Tekin Spec-R motors aren't happy and are saying I must be cheating, ha! I bought mine from Team Eric Anderson Motorsports, so it's not certified, but Eric tuned the motor for me so I can't say exactly what the timing is set to, but it kinda looks close to 47° if I had to guess:
*** It's also worth noting that I noticed my fast lap time drop 0.4 sec this past week, so I rebuilt the car and found a crunchy bearing that needed to be replaced, hopefully I get that time back next race day ;)
Thanks, I'll just have to fiddle with it myself and see what happens.
MarkA 11-24-2017 12:18 PM
Do you have the "regular" or the "maxzilla" one with the HT rotor? You can generally run more gear/timing with the HT rotor which leads to better laps times, especially in 13.5/4w.
The other thing with Trinity motors is that ever since they started offering the "Certified plus" motors for as much as a high-end ESC (!?!), they're basically admitting that's where the good ones are going and while I don't personally run anything from Trinity anymore, I've heard it in-person from several people who do that the more base model ones have become much more hit or miss as a result.
MarkA 11-24-2017 12:23 PM
Not familiar with the FDR in the XB4, but I'm running that same motor in my Tekno EB410 with 24/81 gearing and it's by far the fastest car at my club)
Internal ratio on the XB4 is 1:2.5 but I don't know what it is on the Tekno...
I run 75/25 on a Schurrspeed 13.5SS w/12.5mm rotor on my XB4 so the OP should be in the ballpark on that.
billdelong 11-24-2017 03:31 PM
IDR on Tekno is the same 2.5:1
My Monster Max came with a High Torque Rotor and Low Resistance Stator, Eric Anderson marked the box with (10.5 - 10.6 - 10.7), I have no idea what those numbers mean?
That being said, since 24/81 is doing well for me, then I would probably give 23/78 a try... I plan to drop to 22/81 tomorrow and see if that feels any faster, they won't have the timing loop on so it will be just a "feel" but I do expect to race on turf the following week... this week our club is racing on the 1/8 track and they alternate between the 1/10 and 1/8 tracks each week.
https://c1.staticflickr.com/5/4471/2...dafc35d2_c.jpg
biz77 11-24-2017 04:32 PM
Thanks.
Is this an older Monster motor or the newer Monster Max (not to be confused with the older Monster Maxzilla,which is the old stator with the 12.5mm torque rotor)? If it's the older Monster (does not say "MAX" on the back) then yes it will be a little doggy compared to the current crop of motors. If it's a Monster Max then it should be on par with all of the newest motors.
EricW 11-26-2017 11:00 AM
It's not the Max motor, guess I'll just have to tune it and gear it a bit more aggressively to get more out of it.
Thanks guys.
biz77 11-26-2017 04:17 PM
Thanks guys.
You have two options:
1. Buy a new motor to keep up with the other new motors
2. Accept the fact that you don’t have the newest motor and you are going to get beat by someone with equal driving skill simply because they are out powering you.
Welcome to brushless blinky “stock” racing. We’ll see if ROAR’s new motor rules curb this disparity in the future.
Tanis103 11-26-2017 06:20 PM
I like the timing on my Trinity motors around 56 degrees, they start to come alive over 55. Then I gear to the track and always use a fan.
Kraig 11-27-2017 06:57 AM
Is this setting based on the markings on the can or using a tool that measures the timing?
Tanis103 11-27-2017 05:51 PM
Marks on the can.
faqcya 11-27-2017 06:00 PM
If you have a ampmeter that can measure 10 amps just set it between 5 and 6 amps and gear it accordingly.
EricW 11-28-2017 04:47 PM
I have one. I know the supposed sweet spot for 17.5 is 6 amps, wasn't really sure what it was for a 13.5 motor. I'll give it a shot and see what happens, thanks.
biz77 11-29-2017 12:46 PM
YMMV using this mythical method of setting timing on a motor. My 17.5 Motiv motor runs best at 3-4 amps.
This 6 amp method of testing motors is akin to taking gasoline engines and running them at a set amount of fuel consumption and making comparisons about how they perform on a racetrack based off of that.
