-   -   Orion esc (https://www.rctech.net/forum/radio-electronics/1001055-orion-esc.html)
jt2426 10-25-2017 03:06 PM
Orion esc
I need help on a orion esc can't get it set up to my receiver it's a vortex r10 looks to be a couple of years old
mdwaeracer 10-25-2017 03:28 PM
Check that you don't have to reverse the throttle on your. Radio.
jt2426 10-25-2017 03:36 PM
Just the steering works that's all no thottle response
EbbTide 10-25-2017 03:38 PM
Did you calibrate the ESC?
jt2426 10-25-2017 03:40 PM
No I have tried can't get it to calibrate
Tbuggy 10-25-2017 03:44 PM
Its pretty simple. Do you have the manual?
http://www.team-orion.co.jp/web/inst...series_ESC.pdf
Press the button on the ESC then turn on your transmitter. Once you turn on the transmitter you will see red lights start to flash. Let go as soon as this happens for calibrating.
If you want to make adjustments then hold the button for one second after everything has been turned on as the manual indicates
