Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree818Likes
Old 01-31-2005, 09:35 PM
  #1426
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Uh, I have had that signature for a while, and on more than one site I might add. Besides if I am not mistaken, your sig changes like every week or something. So you sir are the sig thief. As far as hacking goes, thats about your speed, just ask Chen Hwa (LOL). But if you can catch me you can hack me. Just be aware that I can give as good as I get, after all I have recently attended the Eric Whippler Driving Academy!
BP SHADOW is offline
Old 02-07-2005, 11:01 AM
  #1427
k_bojar's Avatar
Trader Rating: 30 (100%+)
Any one have a good set-up for a EvoIII for indoor asphalt?? For the track in Hanover, PA???
I know Type "A" tires, but can't think of how else to set the car up..
Any help???
thanks
k_bojar is offline
Old 02-08-2005, 08:53 PM
  #1428
Any help???
thanks
Bring a bumper car and your own personal marshal....
A-Ko is offline
Old 02-09-2005, 12:16 PM
  #1429
k_bojar's Avatar
thanks...already have ran at Hanover - just haven't run with the EvoIII
And the last time I ran there, I chased my TA04R all day - it actually got worse on each and every run :x
k_bojar is offline
Old 02-09-2005, 11:25 PM
  #1430
So did it get looser as the day went on?
A-Ko is offline
Old 02-10-2005, 06:13 AM
  #1431
k_bojar's Avatar
Looser was/is an understatement...It went south very fast...
The worse part is, the night before - in the "warm-up" race - it worked awesome!!! Didn't touch anything on the car - even the same "A" tires, cleaned the same way...
I was baffled to say the least
k_bojar is offline
Old 02-10-2005, 08:35 PM
  #1432
That track really changes quite a bit during race day. Seems really sensitive to weather. If I ever went back there I would try a few more things like dropping the rear hinge pin holders to 0mm, which come at +2mm and sticking with a larger spur, like 96.
A setup like 50 oil, 3 hole pist, springs red,yellow or blue, med swaybars, 2F to 4R droop, 5mm height would be a good place to start. Even staggering the Type A inserts F hard & R softer can help with no airgap. I would not make the setup too soft, just look for something in the middle.
Since you are already in PA I would make a roadtrip practice with your setup. Well it is what I would do. I would start with my best stock motor with the evo few runs later switch to my 19T.
The back corner by the door seemed to give my Evo fits last year. I am sure it would be different this year, which I don't plan on finding out.
Jeff
A-Ko is offline
Old 02-11-2005, 01:22 AM
  #1433
maxepower's Avatar
Default Too much droop in the back!
Is 4 mm your actual travel or the distance under the arms. If it's the actual travel you better limit your travel in the back or the rear will be swinging out going into the corners!
Jeff
maxepower is offline
Old 02-11-2005, 07:33 AM
  #1434
k_bojar's Avatar
Jeff
Thanks for the suggestions...Actually even though I'm in PA, RCO is a 3 hour ride!! from philadelphia...So it would be hard to convince the wife that I "need" to go out there before March
I've just never run the evo up there - let alone a 19T motor at RCO, so I was just trying to find a starting point...
Yea, that portion by the door has been an adventure every year I've been up there (just missed last year because I moved that weekend)...
k_bojar is offline
Old 02-12-2005, 07:27 PM
  #1435
Neil Rabara's Avatar
Originally posted by RC Driver Gary
Funny Neil, funny.
I'm serious.
Neil Rabara is offline
Old 02-13-2005, 01:01 AM
  #1436
Default Re: Too much droop in the back!
Originally posted by maxepower
It all depends on the rest of the setup.
A-Ko is offline
Old 02-13-2005, 05:55 PM
  #1437
BP SHADOW's Avatar
I know the feeling, the 103's used to work awsome in the Saturday night race and would fall way off on Sunday. As far as the tire/insert goes, the track is notorious for graining tires, air gap will just increase the problem. I would run firmer inserts all the way around and soften the car up to get the traction back. Maybe run the wheelbase biased to the rear to get the weight on the rear tires. That back corner is a killer, it has to do with the heater kicking on and off and blowing the dust around. Not fun. As a side note, maybe B's with soft inserts and lots of air gap might be an option, I know it sounds crazy, but if you use tire warmers to get a little heat in them it might work.
Old 02-28-2005, 02:23 PM
  #1438
snopro31's Avatar
Trader Rating: 57 (100%+)
What changes in the mini do people find needed to run in a tcs race?
Also what do people do for the tb02 and the ta04r to get them ready to race gt2? are alot fo guys running ceramic bearings and stuff like that?
Also any motor tuning tips for the silver can ?
snopro31 is offline
Old 02-28-2005, 03:07 PM
  #1439
eeyan's Avatar
TA04R... old but deadly...
eeyan is offline
Old 02-28-2005, 03:23 PM
  #1440
snopro31's Avatar
so right out of the box only needing a set up no parts needed anything?
snopro31 is offline
