Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree818Likes
Old 05-04-2010, 11:47 AM
  #13306
Trader Rating: 54 (100%+)
Do you find that the track is too smooth to be grippy?
Yellowtaro is offline
Old 05-04-2010, 12:16 PM
  #13307
Hebiki's Avatar
Trader Rating: 26 (100%+)
are you asking me? if you are.. i think grip has suffered lately because of all the rain we've had.
Hebiki is offline
Old 05-04-2010, 12:20 PM
  #13308
I agree but I think it may be more than the rain that is washing the grip away. Hopefully, decent amount of traction can be maintained for the track. The traction deteriorated quite a bit from when it was first paved.
Old 05-04-2010, 01:18 PM
  #13309
240Z's Avatar
Any chance of some traction spray on the track for May 16? It may not be too big of a deal for 4WD or mini, but F1 could use a little help just to get around the track.
240Z is offline
Old 05-04-2010, 01:27 PM
  #13310
OSherman's Avatar
max, yup.. ill be at the track this sat. see you then.
(not esc related).... but you what i noticed about the new track surface.... wear isnt as bad. in fact... ive put on about 20 runs on my B3s. there's still dropoff (granted).. but the old surface was MORE brutal on tires.
yeah, i noticed too.. but dont get the 3-6 solid runs out of tires like we did at slower speeds. back to 2 again..
OSherman is offline
Old 05-04-2010, 01:29 PM
  #13311
OSherman's Avatar
it always does.. enjoy it while it lasts.. once the gaps in the surface fill with crud. done!
OSherman is offline
Old 05-04-2010, 02:13 PM
  #13312
Hebiki's Avatar
unfortunately, im not in charge of that. im sure tamiya will be busy the next two saturdays.. plenty of traction will build up.
Hebiki is offline
Old 05-04-2010, 02:22 PM
  #13313
OSherman's Avatar
Questions?? Can someone help me with this?
any suggestions?
http://www.rctech.net/forum/7359146-post10827.html
OSherman is offline
Old 05-04-2010, 02:54 PM
  #13314
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by OSherman
heat them up
robk is offline
Old 05-04-2010, 02:56 PM
  #13315
Hebiki's Avatar
nope.. i ended up going back and using the carbon reinforced steering arms...
Hebiki is offline
Old 05-04-2010, 04:32 PM
  #13316
OSherman's Avatar
Originally Posted by robk
heat them up
tried that.. maybe i need to 'put em in the oven' heat em p.. lol
OSherman is offline
Old 05-04-2010, 05:09 PM
  #13317
TeamB&B's Avatar
No. If the bearing race is inside the aluminum, then you want to freeze the whole assembly. The steel bearing race will contract faster than the aluminum.
If this doesn't work, then cheapest solution is to destroy the bearing from the inside out.
TeamB&B is offline
Old 05-04-2010, 05:21 PM
  #13318
rccardr's Avatar
Step one: heat entire assembly in oven at 200 degrees for 10 minutes
Step two: spray ONLY BEARING with Freeze-it or upside-down can of keyboard cleaner.
Step three: tap gently, bearing will fall out.
rccardr is offline
Old 05-04-2010, 05:29 PM
  #13319
TeamB&B's Avatar
This is a slightly better solution. Thanks Doc.
TeamB&B is offline
Old 05-04-2010, 08:31 PM
  #13320
Run Plastic!
A-Ko is offline
