Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree828Likes
Old 06-17-2009, 10:02 AM
  #11041
What's the silver can rpm limit for the upcoming race at AV? I heard it was 13,500, but just wanna be sure...
stitchy is offline
Old 06-17-2009, 10:10 AM
  #11042
Trader Rating: 32 (100%+)
I hear no motor limit.
racenut123 is offline
Old 06-17-2009, 10:22 AM
  #11043
rccardr's Avatar
Fred said 13.5 a couple weeks ago.
rccardr is offline
Old 06-17-2009, 10:31 AM
  #11044
AWK
AWK's Avatar
Motor limit for silver cans will be 13,500rpm.
AWK is offline
Old 06-17-2009, 10:44 AM
  #11045
Are we running 2 qualifiers and a main for next week event ? Or trible A mains ?
Thanks !
afung1 is offline
Old 06-17-2009, 11:34 AM
  #11046
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks !
3 or 4 qualifiers depending on the number of people who show up.
Triple As. (per Fred saying last sat.)
if its 3 quals... 2 quals on sat... 1 sunday morning.
if its 4 quals.. 3 quals on sat... 1 sunday morning.
Hebiki is offline
Old 06-17-2009, 11:48 AM
  #11047
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by John St.Amant
Tamiya should make all the F1 cars run the new premounts.
As far as I know the only ones with the brand logo are the $70+ premounts.
They seriously don't have a real way to check what foam people are using. I'm certain that at Scotties people were using non-Tamiya foam. Very certain!
I beat everybody except Randy Bernard with HBR Medium Fronts and Premount Rears. I hope you're not saying Randy was cheating.
robk is online now
Old 06-17-2009, 12:06 PM
  #11048
RaceBucks's Avatar
Tamiya should make all the F1 cars run the new premounts...
I think that would make sense at the Finals if the class was a Japan trip, but at the regionals you should at least be able to run what came in the kit.
RaceBucks is offline
Old 06-17-2009, 01:06 PM
  #11049
Hebiki's Avatar
Default Mini FDR
to the Mini experts...
whats the highest FDR you can achieve in Minis? im assuming the biggest pinion is 21T...
thanks!
Hebiki is offline
Old 06-17-2009, 02:10 PM
  #11050
Trader Rating: 28 (100%+)
Per the confirmation email I received for the race rules, it said the 13.5K silver can motor limit is was for Mini, GT3.
1. Driver check-in is from 7:30 a.m. to 9:00 a.m. All racers are REQUIRED to
check-in at the TECH Inspection Area during this time. Driver raffle tickets
will be given at this time.
2. Power and tables will be available under the covered pit area. If you
have your own "quite generator", you may bring it if you want to pit
somewhere other than the covered area. If you bring your own EZ-UP and
tables you may set it up Friday afternoon.
3. Controlled class practice will be from 7:30 a.m. to 9:30 a.m. The class
order is as follows: Mini, SPEC, GT-3, GT-2, GT-1 and F-1. Off-road entries
may practice at any time.
4. In the Mini and GT-3 classes the RPM limit of 13,500 will be in effect.
5. In the GT-2 class all racers must submit their LRP 17.5 and Novak 17.5
motors to TECH prior to using them. This will be done prior to the
qualifying heat races. Remember! These motors have to have either the yellow
or orange ring on them! The TECH officials will make sure these motors do
not have advanced timing cranked on them. If they do, you will be asked to
put the motor back to ZERO timing and we will put a seal on the motor
showing that it has been pre-inspected for the regional race. These tags are
not to be removed.
6. All Lipo batteries will be checked for voltage at TECH prior to all heat
races. 8.44 volts is the limit.
7. GT-3, GT-2, MINI and F-1 will run 8 Minute Mains!!!!
F1 was not mentioned in the list of classes, so I will assume their is no motor RPM limit for F1.
Can you confirm?
madjack is offline
Old 06-17-2009, 03:42 PM
  #11051
over gear's Avatar
Trader Rating: 18 (100%+)
according to the comfirmation email:
"Racing Format: . Three rounds of qualifying. Your two best combined times will seat you forthe MAIN events. There is one throw-out.. Single A-Mains with Bump up. Thank you, TCS Race Director,Fred Medel"
over gear is offline
Old 06-17-2009, 03:50 PM
  #11052
Hebiki's Avatar
awww boo! well less tires to use then.
Hebiki is offline
Old 06-17-2009, 04:24 PM
  #11053
mcmickey83's Avatar
Default 13.500 rpm
i heard braden was running a 11.200 rpm when he won in freemont just thk what will happen to all the mini guys now that branden is running a 13.500
bring ur shoes lol
mcmickey83 is offline
Old 06-17-2009, 05:55 PM
  #11054
Super Moderator
charlie_b's Avatar
Just for you Mickey.
charlie_b is offline
Old 06-17-2009, 06:14 PM
  #11055
Nova F1 Racer's Avatar
Originally Posted by Notso
Ashby what were you eating too many oysters again? Jay Sharpe couldn't get into a top ten if he was the last guy on the planet he will be lucky to make the D main again.
My top ten
NorCal racer
SoCal racer
Norcal
Norcal
Norcal
and the guy from maryland that cheated last year.
OR WHAT
OR WHAT
(Watch your language)... First you bash the MD track and then this little nugget.... What's next in MD you have a stupid comment on?
Nova F1 Racer is offline
