Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree818Likes
Old 02-20-2009, 11:20 AM
  #10351
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
Originally Posted by rccardr
I've gotta admit...this answer has me scratching my head. I mean, I understand that the real deal here is that we don't want another battery on board the car so as to eliminate the opportunity for nefarious and mysterious wiring combinations that might increase performance. But why deny someone the ability to run the fan off of the ESC leads or battery connection? It makie no sense to me.
How about people who use Tamiya's own entry level ESC in combination with a personal transponder? That speed control requires two plugs (one signal, one power), plus you need a third one for the steering servo and a fourth for the PT. So, those guys don't get to run a motor fan because you won;t permit them to connect it to the battery input leads?
Or how about people who run receivers with only three plug sockets & a PT?
Agreed on the BEC thing, but not sure I would be too enthusiastic about the interference or poor performance caused by using a Y-connector to join a fan to the leads for a PT or ESC.
And then there are the non-RC specific fans out there that are the right size but just don't push much air when run at the lower BEC voltage instead of the full battery voltage.
I mean, WHAT'S THE FREAKIN' POINT??!!??!!
I don't know of very many people showing up to the track with a mini cooper or TT01 with the stock speed controller and are so worried about motor temp that they say "this is not fair I want to run a fan on my motor but becuase my $100 personal transponder took up the last spot on my Futaba 4PK reciever I can't run a $30 Fan set up so now what am I supposed to do if my motor over heats which are at a 13,000 rpm limit at 5 volts anyways " Again slightly rediculous bringing up the Tamiya ESC and Personal Transponder and wanting to add a Fan scenario but I love the banter anyways.
SirSwiftAlot is offline
Old 02-20-2009, 11:34 AM
  #10352
reenmachine's Avatar
Trader Rating: 26 (100%+)
If TCS racers weren't notorious for putting an insane amount of effort into exploiting any little loophole in the rules and otherwise gaming the system to the nth degree ridiculous rules like this wouldn't be necessary in the first place.
You reap what you sow...
reenmachine is offline
Old 02-20-2009, 11:46 AM
  #10353
AWK
AWK's Avatar
This is a safety rule as much as anything. We have never encountered a TCS racer running the TEU-101bk and trying to mount 2 fans and running an AMB transponder. In addition for anyone running that esc, additional fans are not necessary.
We do not want people putting an extra soft lipo, and don't like the wiring messes we have seen with people trying to run additional fans. If the fan is not hard wired into the esc such as a LRP TC Sphere, the only way to mount it is through the BEC slot.
AWK is offline
Old 02-20-2009, 12:07 PM
  #10354
lbckevin's Avatar
Trader Rating: 107 (99%+)
Well put Andrew.
lbckevin is offline
Old 02-20-2009, 12:35 PM
  #10355
RaceBucks's Avatar
Originally Posted by CarKing
... We have never encountered a TCS racer running the TEU-101bk and trying to mount 2 fans and running an AMB transponder..
FYI,
I ran my TT-01 last year with the TEU-101bk at TCS, and while I ultimately didn't run a fan I did open it up and re-route the power leads internally to avoid having the extra plug. (probably shouldn't admit that to Tamiya but I doubt I'll ever send it in for warrenty!)
Since I also use the small Spektrum receiver, had I run a fan I would have been out of space if I hadn't modified the ESC's power.
RaceBucks is offline
Old 02-20-2009, 01:25 PM
  #10356
Originally Posted by RaceBucks
FYI,
Jeff you are not normal and we all know that but we still like you. OK thats 1 out of how many racers ? BTW whose silver can were you running? Was it stock?Or was it black Can? Stock?
Old 02-20-2009, 02:00 PM
  #10357
rccardr's Avatar
OK, so Jeff's not normal and I'm a fringe lunatic. We all knew that already.
Nobody's arguing about the no-battery-to-run-your-fan rule, whether for safety or skirt-the-rules reasons. Nor did I ever refer to an installation where there would be both a fan on the esc AND motor or multiple fans of any kind (do people actually run fans on their ESC? Do they get that hot?).
So we're talking strictly about a fan that blows air across the motor and where the power source for the fan originates. It just seems weird to me (not to mention impractical in the two examples given previously, scoffing aside) that you HAVE to run it off of a plug in the receiver. Is it because Tamiya wants us to raise the artistic level of beauty in the neat and orderly arrangment of our wiring? ("We...don't like the wiring messes we have seen...") Is it because Tamiya has a distinct preference for fans that are happy at 4 or 5 volts rather than one that operates better at 7.2 volts?
I mean, maybe I'm stupid (surely not the first time such a situation might be alleged) but I just don't see how it's a safety issue at all. Am I missing something obvious here? And Andrew's statement that the only way to run it is off the receiver if it's not wired into the ESC is just not accurate. I've seen any number of neat, sanitary, safe, well laid out setups where a single motor fan is powered from the battery leads or ESC tabs. Which, I think, was Bill's original point.
rccardr is offline
Old 02-20-2009, 02:08 PM
  #10358
AWK
AWK's Avatar
While we understand that there are ways to do it safe and properly, from the amount of poorly wired cars we have seen through tech, we decided it would be safer and easier to regulate the way these fans had to be wired. It makes it easier for us in tech, easier for the people racing to know exactly what they can do, and makes it safer for those newer to r/c and TCS to wire safely. As I am sure many people have seen, there are plenty of people out there with a rats nest for wiring and with all of the concerns about battery issues with lipo, we want to do our best to keep any possible issues to a minimum.
My comment about the only way to wire the fan if it is not hard wired into the esc was not saying that it can't be done, only that it can't be done per our rules. Sorry for the confusion.
I can understand the frustration, but we are simply trying to keep things easy and safe for the average racer.
And to your two examples, while I can see where you are coming from, we have not had anyone raise any questions or concerns about this until right now. We can revise the rules later on if it becomes an issue, but for now the rules are going to stay as is. Sadly when you think about it, we haven't even had a race to knwo for sure if this, or any rule will need to be revised.
AWK is offline
Old 02-20-2009, 03:01 PM
  #10359
Trader Rating: 44 (100%+)
You read me like a book, Doc. I totally understand not running the soft pack Lipo (as I saw several do at the Nats last year), but why regulate where our one motor fan pulls power? I have a nice, clean set-up with a BEC plug coming off of my ESC tabs, but now I have to pull it off and crimp those blasted 28 awg contacts w/servo plug so I can fit it into a receiver that doesn't accept the 2-pin red BEC plug. Talk about a task you wouldn't want a beginner to tackle!
See Andrew, now you are catching on. No races, no worries. But silly me wanted to take some time preparing my cars for this season, and realized the new motor fan rule made my "fresh off the TCS Nats track" mini illegal for this year. And after screwing up a couple of servo connector terminals, I decided to ask the question. Asked, and now answered. I will comply to the rules, and hope that it is regulated so that all participants are asked to follow these new rules.
And while we are on the subject of making the wiring safer and easier for the beginners out there, why don't we keep the bullet connector rule for the motors? I've still got mine from the Nats. Allowing someone to hard-wire a motor sort of defeats your logic for not allowing someone to hard wire a motor fan, don't you think?
p.s. - It's all in good fun. I just thought I'd throw something out to get the chatter going again. With all of the race cancellations, we gotta do something!
minimadman2003 is offline
Old 02-20-2009, 03:53 PM
  #10360
AWK
AWK's Avatar
The reason we don't keep the bullet connector rule is because a lot of the aftermarket escs do not come with bullet connectors installed. By enforcing this rule, you are hypothetically making people do more wiring and soldering than they would other wise by having to install the bullet connectors on the esc and maybe on the motor as well depending how their motor came. Also, we have not seen the same wiring issues with motors as we have with the fans.
All we can say is go by the rules and your car will be good to go! Come on, we have had that rule posted since November!!! Plenty of time for your car to be wired up all pretty
We are going to do our best to make sure at our races everyone will comply, and also ensure that the stores hosting our events do the same.
All in fun is right, don't worry about that! This thread died for a bit so it's nice to see some chatter on here.
AWK is offline
Old 02-20-2009, 04:13 PM
  #10361
RaceBucks's Avatar
...BTW whose silver can were you running? Was it stock?Or was it black Can? Stock?
It was at the regional last year with the RPM limits so it was a standard water dipped motor; I was Granpa and Red Dot free so no need for a fan.
My current motors are still Granpa and Red Dot free, but now seem to benefit from a fan
Old 02-20-2009, 05:32 PM
  #10362
Core Creations's Avatar
Trader Rating: 110 (100%+)
Might I suggest the high RPM Muchmore fan...those things rip even at 5 volts!!
Core Creations is offline
Old 02-20-2009, 05:33 PM
  #10363
Kevin CBR's Avatar
I ran a "soft lipo" to power my fans last year at the Nats. Very clean and safe set-up and since we had to add weight anyways, what the heck, right ? But I can understand Tamiya's concerns with people runing small soft lipo packs to power fans when they require hard case lipo's to power the car only. So, the rule has changed and so has my wiring. It's called a Y-connector available at most any LHS that you plug into your receiver and now you can run two items (like a fan and a personal transponder) from the one receiver slot. And it mounts so nicely on top of the steering servo with some good double back tape. It worked so well, that for my RCGT series car, I am running two motor fans, a personal transponder AND the Tamiya lite unit for headlight and tailights on my car, all through the receiver. Humm, no problems. I guess those little KO receivers are pretty good !
Kevin CBR is offline
Old 02-20-2009, 07:46 PM
  #10364
rccardr's Avatar
Aha. Now I understand.
We DON'T insist that racers insulate both wires on their power plugs.
We DON'T make racers charge their Lipos in a Lipo sack.
In fact, we DON'T even check to see if they are using a Lipo charger to charge their Lipo cells.
We DON'T tech the gloppy soldering jobs that cause battery plugs to heat up and/or melt.
We DON'T get worried when the occasional 4200 cell blows off in the pits because somebody's a 'chargin at 15 amps.
We DON'T expect racers to neatly bundle, tie-wrap and secure their general wiring.
But we DO insist that racers plug their fans into the puny 5-volt sockets in their receivers because...IT'S SAFER!!!
How could I have been so blind???!!!???
rccardr is offline
Old 02-20-2009, 08:27 PM
  #10365
maxepower's Avatar
Default TCS Series RACE!
TCS races are not a ROAR sanctioned race so that means that Fred has to set a standard regardless of it being a saftey issue of ease of inspection for racing. There are racers that will be upset about one rule or the other and you can't please everybody, although Fred has tried his best to get input from a lot of racers to make it a better sport.
A lot of young novice racers run TCS for the first time and usually come with family and friends. In other words a lot of eyes are watching what's going on in the pits,ie. no profanity,smoking, open toed shoes, spec. tires, rims, batteries, bodies, cheating, etc. etc.
I think spectators watching the race will leave thinking that this is great hobby and they would want to come back and watch or participate. This can only help the sport grow!
I believe Fred has the authority to set standards for his races. Nobody is forced to race TCS ,so if someone doesn't like all the rules then don't run TCS. For that matter ROAR races included!
That simple!
Just my 2$
Hey Kevin,
Are you going to Tamiya tomorrow? Should be a nice day!!
maxepower is offline
