Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 01-19-2009, 10:20 PM
  #10156
minimusprime's Avatar
Trader Rating: 19 (100%+)
so who do we have to suck up to to get the track opened friday the 6th of feb for practice? does it help that it's my birthday. I'll just view it as a big thank you from tamiya for buying so much stuff over the years.
thanks in advance fred.
minimusprime is offline
Old 01-19-2009, 11:59 PM
  #10157
Originally Posted by maxepower
I was told that the motor limits are going to be 13,000rpm's max at 5.0 volts. So there is a little room to break in the motor and stay within the limits!
Just my 2$
Most of the new red pip 540s, tach out at 12.3 -12.5k. There are a few that will be in the 12k range and I had one get to 12.8, but that one will be in MY Mini. The size of the sample is over 30+ motors and all of them were tested after a break in that fully seated the brushes.
Just a guess, but a new, fresh out of the box motor will be c. 500 rpm less. You can safely break in a motor and stay under the 13k motor limit. That's with the red pip ones. The white pip ones may be a little faster, but can't swear to it, as a sample of only 2 motors isn't large enough to come to any solid conclusions.
Granpa is offline
Old 01-20-2009, 05:18 AM
  #10158
CSeils's Avatar
Trader Rating: 54 (100%+)
Just curious, has anyone used the carbon racing wing on a Lexus body? Looks like it might be at a weird angle. Just wondering what it would look like before I drill holes.
CSeils is offline
Old 01-20-2009, 07:16 AM
  #10159
reenmachine's Avatar
Trader Rating: 26 (100%+)
If you're talking about the carbon-print lightweight wing, then yes, I have used it on the SC430 Lexus and it worked fine.
reenmachine is offline
Old 01-20-2009, 07:23 AM
  #10160
CSeils's Avatar
Did you need to do anything to the mounts?
CSeils is offline
Old 01-20-2009, 07:36 AM
  #10161
f1larry's Avatar
Trader Rating: 22 (100%+)
Carl,
Doesn't the wing mounts come with 2 little plates that can be turned forwards or backwards to adjust the angle of the wing. I know Other Tamiya hop up wings have come with them to adjust the downforce. Maybe you just need to turn them around to adjust the angle on the wing.
Larry
f1larry is offline
Old 01-20-2009, 07:40 AM
  #10162
No, and there were even little dimples on the body in the correct locations for the holes. The wing angle is indeed adjustable by repositioning the base.
Old 01-20-2009, 07:42 AM
  #10163
CSeils's Avatar
With the angle of the trunk, I just wanted to make sure the wing mounts would still work like they were intended to do. Thanks.
CSeils is offline
Old 01-20-2009, 10:09 AM
  #10164
mkdut's Avatar
Couple of Doc Red Dots for sale at discounted prices
http://www.rctech.net/forum/5318305-post1.html
mkdut is offline
Old 01-20-2009, 11:44 AM
  #10165
Hey uhh.. whats the part # on that carbon wing please!?
and ty....
John St.Amant is offline
Old 01-20-2009, 11:50 AM
  #10166
CSeils's Avatar
John St.Amant
and ty....
53470
CSeils is offline
Old 01-20-2009, 11:51 AM
  #10167
and ty....
53470
Tamiya Light Weight Wing Set (Carbon Print)
Old 01-20-2009, 12:43 PM
  #10168
Trader Rating: 35 (100%+)
Anyone here know if the Novak 17.5 brushless (TCS legal, version) is available with the GTB ESC as a package, or do you have to purchase the motor and ESC separately?
All of the images of the Novak 17.5 ESC/Motor systems depict a motor without the yellow ring??? And the part number supplied on the TCS Rules page is for the motor only.
Thanks!
Geppetto is offline
Old 01-20-2009, 12:57 PM
  #10169
Hebiki's Avatar
Thanks!
im guessing thats just an old picture. all the new novak 17.5s ive seen all have the yellow timing ring. best thing to do is email someone at novak and confirm before you purchase.
- Chris
Hebiki is offline
Old 01-20-2009, 01:34 PM
  #10170
- Chris
Thanks Chris. I did send an email to Novak, but they must be closed for the weekend/holiday since I haven't heard anything back.
Geppetto is offline
