Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 07-26-2007, 08:11 AM
  #5941
414MPH's Avatar
Originally Posted by BP SHADOW
And of course the unwritten but often referred to "Hageman Clause" - If Marty can think it up, it will be deemed illegal:lo l:
Sometimes I just crack myself up
Thanks bradley.....
It's tough to keep a low profile with you and billy and your relentless banter... sometimes you crack me up too, usually on the track...
414MPH is offline
  #5942
Trader Rating: 32 (100%+)
I went back to look and I marked exactly what the guy with the motor checker told me on the can for reference.My best of the 2 motors I received pulled 1.8 amps.Kind of scary to see a 1.5 amp motor limit if these motors after a slight motor breakin is already pulling the 1.5amps.
racenut123 is offline
Old 07-26-2007, 08:18 AM
  #5943
And wasn't the amp draw limit 2.1 amps last year?
Old 07-26-2007, 08:54 AM
  #5944
Sounds like there won't be too much break-in on motors this year......
Marty it's a bit old skool but what color????
Difuser is offline
Old 07-26-2007, 09:54 AM
  #5945
lbckevin's Avatar
Trader Rating: 107 (99%+)
strange when my black can pulled .8 new...so a 1.5 is just a little oil and go.
lbckevin is offline
Old 07-26-2007, 10:04 AM
  #5946
Trader Rating: 28 (100%+)
2.1 or 2.3 if memory serves?
madjack is offline
Old 07-26-2007, 10:27 AM
  #5947
Hebiki's Avatar
Trader Rating: 26 (100%+)
checked mine last night, they were pulling 2.1 to 2.2 . (checked on two different types of motor masters)
Hebiki is offline
Old 07-26-2007, 10:28 AM
  #5948
Thanks John.
I have 10 brand new black cans on the shelf I will be testing for out of the box performance.I will use the Orion motor checker to see what is what.It would be nice to know what method or machine they plan to use as a way to check.It will make a difference.
Old 07-26-2007, 10:34 AM
  #5949
Hebiki's Avatar
Thanks John.
check your break in period. last year one of my motors broke in within minutes (really soft brushes). call me later. we can chat.
Hebiki is offline
Old 07-26-2007, 10:52 AM
  #5950
Thanks John.
we are on the same page... I'm using the MMR box (BTW 06 TCS tech was using the Orion system)
madjack is offline
Old 07-26-2007, 10:54 AM
  #5951
my thing is if you barely break in the brushes and then your motor fully breaks in on a run and it pulls more amps then previously noted, your disqualified? I know Tamiya probably{hopefully} has a basis for the 1.5 amp draw limit,Ahhhhh nevermind.I will figure it out.Anyone been able to source some GP2400 nicads yet?
Old 07-26-2007, 10:56 AM
  #5952
Hebiki's Avatar
good point. i dont remember my motors pulling that high last year. im assuming after i ran them in the mains, they finally got seated..and now drawing more amps.
arent the 2400s... from sanyo?
Hebiki is offline
Old 07-26-2007, 11:10 AM
  #5953
Taken directly from the tamiyausa website under 2007 rules-
"GT-2 and Mini
The GT-2 and Mini classes will be using both a Spec Motor (Tamiya black Sport tuned motor item 53068) and a Spec battery (Tamiya branded GP 2400 ZAPPED NICD assembled Stick pack). These are the same batteries that will be used for the Tamiya World Championships!"
Old 07-26-2007, 11:35 AM
  #5954
eeyan's Avatar
Yes, the 2400 are most likely the NiCd Sanyo ones used in Japan with the blue foil Tamiya label and comes in the Blue box. I might still have a couple at home from the Worlds in 2004; but I know Izzy bought two of those to test last year. I have never seen GP2400 batts... I'm sure that's a typo.
eeyan is offline
Old 07-26-2007, 03:38 PM
  #5955
Trader Rating: 44 (100%+)
Are we talking about Tamiya #55086?
minimadman2003 is offline
