Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 05-25-2007, 06:19 PM
  #5461
Registered User
Originally Posted by A-Ko
If yer talkin regionals GT2
1) bring yer own 27t motors
2) morning before 10am I'd run As (or before the sun peeks out) rest of the day b3s
3) build yer own or buy one
If yer talkin nationals GT2
1) GT2 becomes handout 23turn fer a nominal fee
2) same as above
3) handout stick packs fer a nominal fee
anything else... ayeee
Jeffy, Don't know what you are smking but it must be potent.
NATIONALS GT1 is 23 turn Tamiya Motor, must be purchased and s/#'d at event!
radar is offline
Old 05-25-2007, 07:40 PM
  #5462
rccardr's Avatar
The black can Mabuchi Sport Tuned motors are also 23 turn. If I recall correctly, GT2 at Nats also had to use spec 3300 packs purchased at the event.
rccardr is offline
Old 05-25-2007, 11:25 PM
  #5463
Trader Rating: 32 (100%+)
Thanks guys. I'll pick up some B3s.
As for batteries, even if I build my own, can they be side-by-side or do they have to be stick packs? That's one thing the rules don't really make clear.
ittjv is offline
Old 05-26-2007, 06:38 AM
  #5464
rccardr's Avatar
What type of chassis? OK to use side-by-side for TA04/05. But if the car was designed to take only stick packs then that's what you have to use.
rccardr is offline
Old 05-26-2007, 11:05 AM
  #5465
TA05. Cool.... then I don't have to buy new batteries! Now to find some B3s before it's too late! Thanks for you help guys!!!
ittjv is offline
Old 05-26-2007, 07:49 PM
  #5466
rccardr's Avatar
TWO WEEKS TO FREMONT!! TWO WEEKS!! TWO WEEKS !! TWO WEEKS!! TWO WEEKS!! TWO WEEKS !! TWO WEEKS!! TWO WEEKS!! TWO WEEKS !! TWO WEEKS!! TWO WEEKS!! TWO WEEKS !! TWO WEEKS!! TWO WEEKS!! TWO WEEKS !! TWO WEEKS!!
Thank you. I feel much better now.
rccardr is offline
Old 05-26-2007, 08:03 PM
  #5467
AWK
AWK's Avatar
What inserts are you guys running with the A's and B3's in GT2?
How many sets of tires are you guys using for the weekend?
How many battery packs should a person have?
Is a battery like the Orion IB batteries ok?
Also what motors are looking like the ones to have for GT2?
I am rushing around trying to get the necessary stuff together to be ready for GT2 in late June, but it will be a scramble! Any help is always appreciated.
AWK is offline
Old 05-26-2007, 09:09 PM
  #5468
Inserts depends on the class.... arrrrrg
Tires only last 1 round, if its really hot.
2 batteries for 1 class is safe.
The Co27 has been nice!
A-Ko is offline
Old 05-26-2007, 10:19 PM
  #5469
I'm in scramble mode too! So roughly how many tires would I need for the weekend? 5 sets or so?
ittjv is offline
Old 05-26-2007, 11:35 PM
  #5470
If they are running the Nats type of format, 1 set for each race so if you are looking at 4 qualifying heats and triple A-mains you are looking at 7 B3s.
1-800-TAMIYAA could better answer the format of heats/mains.
Also you cannot forget your practice tires, which you could run more than once. Depends how competitive you think you will be on the track, as well as how much you can afford?
A-Ko is offline
Old 05-26-2007, 11:42 PM
  #5471
Thanks again, A-Ko. You're a big help! The rules say:
2. All races are 5 minutes in duration.
3. There will be two qualifying heats to determine the Main set-up order.
4. The qualifying format will be left to the discretion of the host site. The two options are IFMAR qualifying and heads ups qualifying starts.
So I guess I won't need to buy so many sets. Man TCS is expensive!
So, can anyone clue me in on what "THE" body to run is?
ittjv is offline
Old 05-27-2007, 12:21 AM
  #5472
lbckevin's Avatar
Trader Rating: 107 (99%+)
Jose,
Check out my post a page or two back. I listed the bodies used at the Nats.
lbckevin is offline
Old 05-27-2007, 12:33 AM
  #5473
Thanks, Kevin! I found your post, but it was in the TA-05 forum.
Sent you a PM....
ittjv is offline
Old 05-27-2007, 04:59 AM
  #5474
rccardr's Avatar
1. All races are 5 minutes in duration.
Remember that Aliso is a two-day event, with two additional qualifiers- probably only three on Saturday since it seems thay will not have the track open for practice on Friday- with a fourth Q on Sunday morning and then the Mains. If it's run like Seattle they will have triple A's and double B's. Note that Seattle also had 6 minute Q's and Mains. Like the rules say, format is up to the host site...
rccardr is offline
Old 05-27-2007, 03:10 PM
  #5475
Thats what I was figuring. . .
A-Ko is offline
