Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 04-24-2007, 10:09 AM
  #5296
We ran a Novak 6.5 in the Tamiya 4 hour Enduro last year with no issues and it was as fast at the end as it was at the start.
DOTMAN is offline
Old 04-24-2007, 10:21 AM
  #5297
linger's Avatar
Originally Posted by eeyan
And you said you were retired. D@#! you Ling... not fair! I knew you've been practicing all this time? Gotta find that Area 51 in Norcal... Geez, I thought we were both going to $uck at Reedy... I guess I'll be alone in J-Main. j/k!
Eeyan - I am retired. I get to test lipo batteries for work - performance testing, life cycle testing, safety testing etc. I have a stash of a couple thousand lipo cells from over 10 different manufacturers - literally.
I'll be racing mod at the fun race this sunday. You get to see just how much I suck now. I suck sooo bad, that I now swallow too.
I'll be running the same 415 that I started using back in 2004. Is there an antique class?
linger is offline
Old 04-24-2007, 10:24 AM
  #5298
OSherman's Avatar
Thumbs up The Way of the Future
LiPo/Brushless...
OSherman is offline
Old 04-24-2007, 10:26 AM
  #5299
eeyan's Avatar
Red face
Ling,
Oh okay, I thought you work at a nuclear power plant. How many tons of Lipo did you say you guys have? Hopefully not enough to separate San Francisco into a detached island...
BTW, according to Dan's scribblings under Chris' TA05... Chris swallows too... whatever than means...
eeyan is offline
Old 04-24-2007, 10:55 AM
  #5300
Garber's Revenge
Difuser is offline
Old 04-24-2007, 11:30 AM
  #5301
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Difuser
Garber's Revenge
i still remember you wrote on that chassis when it was brand new!
Hebiki is offline
Old 04-24-2007, 02:28 PM
  #5302
Yeah and then I help you setup the car, loan you parts and then I am an all around good guy. What's a little graffiti in the chassis, plus you must like it since Sharpie comes off with Motor spray...........
Juan's car was alot worse after he felt up the little kid (oops maybe I should add got and by in there)
Difuser is offline
Old 04-24-2007, 03:00 PM
  #5303
Leester's Avatar
Trader Rating: 23 (96%+)
Originally Posted by RCGaryK
Here you go Lee:
http://www.horizonhobby.com/Products...ProdID=DYN4058
Or
http://www.horizonhobby.com/Products...?ProdID=THP425
I've used both. I use the Thunder Power one on my 3-Cell airplane stuff, works awesome. That's the nice thing about LiPo...there AREN'T any mumbo-jumbo charging techniques. If it's a 3200Mah battery, you charge at 3.2 amps. 4800? 4.8. It's pretty simple. Even Marty can do it!
gary. i just bought the dynamte Lipo charger. and the 3200 race spec. I need to know what setting i need to set it at. So i don't blow the battery up. I would like to know some of the safety tips, and how to take care of it before i take this battery for a spin. I already use bullet plug conectors. Also do i need the novak lipo cut off regulator? tell me. what do i need to do to keep this thing from blowing up nad making a mess?
-Lee
Leester is offline
  #5304
Leester's Avatar
Leester is offline
Old 04-24-2007, 03:04 PM
  #5305
414MPH's Avatar
Here you go Lee:
Or
GK, The chargers you linked to only charge at 2.0 and 2.5 amps MAX. This will require extended charge time and no battery benifit.
Leester, I would buy a charger that can charge at higher rates. For additional info read Ling's research... http://www.rctech.net/forum/showthr...=lipo+awareness
Lipos need to experienced to be be appreciated. Racers, start using them at your local tracks and demand a class for them. Others WILL follow....
MPH
414MPH is offline
Old 04-24-2007, 03:06 PM
  #5306
414MPH's Avatar
leester, sorry I type slow.....
414MPH is offline
Old 04-24-2007, 03:07 PM
  #5307
RCGaryK's Avatar
-Lee
Lee, just set it to 2 cells, and a 2 amp charge rate and you'll be fine. The Novak cutoff isn't a bad idea. I haven't used on myself, but it would prevent you from over-discharging your LiPo.
Safety Tips:
Never discharge it below 3.3 volts per cell or 6.6 total volts
Don't short it out
Don't charge it with anything but a LiPo charger
The 3200 is a really good battery and the Dynamite charger works really well. It'll take a little over an hour to charge. One weird thing with Lipo is the "reverse peak" that it has on track. By that I mean the battery will INCREASE it's voltage output after you've run for a little bit. What happens is as the cells heat up, the chemical reaction actually speeds up which will increase the voltage. It's kinda weird but it's noticable on the laptimes.
RCGaryK is offline
Old 04-24-2007, 03:09 PM
  #5308
RCGaryK's Avatar
MPH
Right, but for the pricepoint he was looking for he wasn't going to find anything with a much higher charge rate.
RCGaryK is offline
Old 04-24-2007, 03:16 PM
  #5309
Core Creations's Avatar
Trader Rating: 108 (100%+)
The Orion Avionics and the Multiplex lipo chargers are awesome for the money...around $70 and can charge up to 5.0 amps.
Core Creations is offline
Old 04-24-2007, 04:07 PM
  #5310
414MPH's Avatar
Team Orion Avionics Advantage Park Flight Charger, 29.99. Charges at up to 3.0 amps and it's "ORION"
http://www2.towerhobbies.com/cgi-bin...?&I=LXNAC2&P=7
Sounds like a better deal to me.......
414MPH is offline
