Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree828Likes
Old 01-13-2007, 04:56 PM
  #4696
tamiyarcracer's Avatar
Originally Posted by A-Ko
Since a preview of the Nats is posted, which is little more than 7 months away, I wonder if they will allow participants to run a Worlds class and another class? Althoug it may not change anything for me, just a curiosity.
Jeff I would think that Fred would not do that because of Time constraints, for the neighbor hood curfew. I think that they found in 2003 that ist made the racing last longer and it was harder to control When they let people race mini, and another class that year.
tamiyarcracer is offline
Old 01-13-2007, 04:57 PM
  #4697
Core Creations's Avatar
Trader Rating: 110 (100%+)
regional racers are limited to 2 classes correct?
Core Creations is offline
Old 01-13-2007, 05:16 PM
  #4698
Trader Rating: 44 (100%+)
Ok all you LiPo experts......
Are there any performance differences between the Carbon and the Platinum? I understand that the Carbon is a 3200mAh and the Platinum 4800mAh, and that the Platinum is roughly $50 more. But what about performance (other than run time)? I was looking for weight specs, and found a few sights claiming they also weigh the same. Also, does one fit the cars better than the other?
Thanks!
minimadman2003 is offline
Old 01-13-2007, 05:19 PM
  #4699
Dimensions 3200mAh:
Length - 137.5mm
Width - 46.7mm (17.5mm radius sides to emulate stick pack shape)
Height - 23mm (20.5mm height between bumps)
Weight - 198g (6.6 oz.)
Dimensions 4800mAh:
Length - 137.5mm
Width - 45mm
Height - 23mm
Weight - 258g (9.1 oz.)
I have both and don't feel any advantage over each other.
Old 01-13-2007, 11:24 PM
  #4700
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks!
in my personal experience. there are no performance differences that i felt between the 4800 and 3200. i used the 4800 at the KO Propo GP since it was heavier, i had to add less weight to the car to make minimum.
Hebiki is offline
Old 01-14-2007, 10:08 AM
  #4701
They do run off a schedule and know what kind of time constraints they are up against and where the last race ends. It might be worth a thought have class entry limits on non-Worlds classes and give priority to 1 people entries vs 2. I never ran 2 classes at the nats, although sometimes I wish I could.
A-Ko is offline
Old 01-14-2007, 10:09 AM
  #4702
What kind of runtime have you guys been getting with what chassis and motors?
A-Ko is offline
Old 01-14-2007, 10:35 AM
  #4703
RCGaryK's Avatar
My question about the LiPos would be:
Since the Orion packs are made in conjunction with Kokam, would there be any consideration to making the equivelent Kokam packs be legal as well?
RCGaryK is offline
Old 01-14-2007, 11:03 AM
  #4704
rchoudini's Avatar
Just so everyone can plan we will be running the Tamtech class at Regionals so bring your Frog's, desert gators and the rest.
rchoudini is offline
Old 01-14-2007, 12:12 PM
  #4705
I wish we were able to run the 3200 lipo in mini..I use about 600 mah in a 5 minute race! In 4300/foam with my TA05 I use about 1950mah with the 4800 lipo!
Old 01-14-2007, 02:21 PM
  #4706
Wow thats pretty cool. With your TA05 was that with stock 27t or a 19t?
That could be really cool with mini. Just charge once and good to go for the day.
Do the packs fall off much, heat up or need to rest for next charge?
A-Ko is offline
Old 01-14-2007, 03:45 PM
  #4707
It's running 4300 brushless foam on carpet...almost as much amps as mod. The batteries in the TA05 come off at 90-95 degrees and go right back on the charger, no break. I've used it this way for a long time with no ill effects. They don't fall off at all...not even a little.
In the mini the pack comes off at room temp. We've pondered charging once and running all day, but just choose to repeak. They are the best thing since sliced bread, period!
Old 01-14-2007, 07:49 PM
  #4708
C_O_jones's Avatar
Silly question Mayo, only Orion would give Fred a kickback.
Just kiding Fred, just kiding.
Derf
C_O_jones is offline
Old 01-14-2007, 09:02 PM
  #4709
Are Kokam in a case?
Old 01-14-2007, 11:26 PM
  #4710
AWK
AWK's Avatar
I didn't see any rules on it, so should we assume the body rule is gone? I actually really liked that rule from last season! Nice seeing people in GT2 and GT3 not running all NSXs for a change.
AWK is offline
