Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree818Likes
Old 01-09-2007, 01:34 PM
  #4636
muahdib4's Avatar
Originally Posted by OSherman
....Silver or Black..
Which is faster?
Which seems to be the 'choice'?
What is this elusive 'four hole' can i have heard about?
-O
Black is faster but isn't a "stock" silvercan either so it doesn't really count. The 4-hole is an old Mabuchi motor and they're supposed to have a LOT more RPM than the normal 2-hole Johnson silvercan. I've never had any of them so I can't say from personal experience if they are. The choice is basically to buy a LOT of stock Johnson silvercans, break them in and put them on a dyno and pick the best...sell the rest. It's really the only way.
muahdib4 is offline
  #4637
Hebiki's Avatar
Trader Rating: 26 (100%+)
Which is faster?
-O
black can is faster.. but burns up quickly. there's a johnson and mabuchi silver can. johnson is faster. the older "4 hole" ones are faster then the recent 2 hole. but depending on who you ask... it all varies "depending" on how you break it in.
what works in mini generally never works in touring car (mini require less torque) and what works in touring car isnt fast enough in a mini.
i could reveal more... but then i would have to kill you. there isnt any open memberships right now in the inner circle of silver can tuners club.
Hebiki is offline
Old 01-09-2007, 01:44 PM
  #4638
tomdav's Avatar
Trader Rating: 44 (100%+)
So Hebiki are you a goldmember of the silvercan club?
tomdav is offline
Old 01-09-2007, 03:17 PM
  #4639
OSherman's Avatar
Thumbs up
interesting...
and what does this 'four hole' can look like exactly... where are the four holes?? on the can? endbell?
-O
OSherman is offline
Old 01-09-2007, 03:24 PM
  #4640
crunchracer's Avatar
interesting...
-O
In the can, hard to find, unless you get lucky. Honestly buy some new 540J, break them in , check them for the atributes you need, and pick what you want to keep dump the rest.
crunchracer is offline
Old 01-09-2007, 03:27 PM
  #4641
Talking
Bad Boy, you got close to revealing to much info
Old 01-09-2007, 03:39 PM
  #4642
Trader Rating: 28 (100%+)
ahhh yes, the continued TCS silver can madness...buy many...race few
madjack is offline
Old 01-09-2007, 04:39 PM
  #4643
f1larry's Avatar
Trader Rating: 22 (100%+)
Originally Posted by RaceBucks
I got my daughter a TT-01R to run in the Spec class; but is it legal?
It came with the legal hop ups, but the stock pinion is a 22T and the stock motor is a 25 turn. I assume I need to get the 19T pinion (see rules) and run a silver can. Other than that is it legal?
As the spec rules have not changed over the years I would think the TT01R is not legal for spec.
For the spec class the car has to be box stock (Basic kit) The only hopups you are allowed to have are bearings, Plastic oil filled shocks and the Aluminum propeler shaft. You also have to run the kit 26mm tires and wheels. It will cost you more to dumb down the TT01R than it will cost you to buy a whole new kit. I just bought my son a new TT01 to replace his old spec car. it was 79.99 on Tower (the 2004 Subaru impreza). You will need to ad bearings and the plastic oil filled shocks.
f1larry is offline
Old 01-09-2007, 05:14 PM
  #4644
tamiyarcracer's Avatar
I need to correct you here, the older 4 hole cans are Johnson motors, atleaset the good ones.
I have never found a Mabuchi I have gotten to perform as well as I can get the Johnsons to perform.
tamiyarcracer is offline
Old 01-09-2007, 05:52 PM
  #4645
tomdav's Avatar
So for the experts out there, are the older Johnsons faster than the newer ones? Why does Tamiya still allow racers to use something that is not available to everyone.
Ok for those in the know what are the odds of lipo rules for mini or 103gt?
tomdav is offline
Old 01-09-2007, 06:03 PM
  #4646
Trader Rating: 15 (100%+)
Default TT01R
You forgot to mention turnbuckle steering tierods and adjustable arms.
I could be wrong, but around 40 bucks gets the car he already has to 06' specs.
blewer is offline
Old 01-09-2007, 06:50 PM
  #4647
KAHUNA's Avatar
Cool
I could be wrong but your never wrong !
Don't tell all your scerets !
KAHUNA is offline
Old 01-09-2007, 07:03 PM
  #4648
Ok for those in the know what are the odds of lipo rules for mini or 103t?
Lipos for F103GT, I doubt it.
The 4 hole Johnsons are faster than the current ones, but they are better when tuned. and tuning them, makes them better in 2WD car cause you loose torque.
Old 01-09-2007, 08:21 PM
  #4649
madjack is offline
Old 01-09-2007, 08:27 PM
  #4650
Originally Posted by madjack
Cat got your tongue John??
