Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree832Likes
Old 09-20-2003, 11:50 PM
  #286
SpeedTech's Avatar
MPH RC,
Thanks for the compliments, unfortunately we do not have the type Bs, but I believe 5 sets is plenty for the race weekend. Usually you can get away with practicing on take of CS27 (which are very similar to new Bs) and getting a setup from that. Plus the fact that you might run a round with As (if you get a round early in the morning or really late in the afternoon/evening) So I think 5 sets is plenty
Good luck everyone! See you all Thursday
Steve Wang
SpeedTech is offline
Old 09-20-2003, 11:56 PM
  #287
tomdav's Avatar
Trader Rating: 44 (100%+)
Default glitching
Did you grind out the gun metal anodizing on the inside of the can near the locking ring? I think I remember this trick from the Reedy race thread. Maybe it was one of those glitch busters from JR.
tomdav is offline
Old 09-21-2003, 07:57 AM
  #288
rtypec's Avatar
Default Re: Glitching
Originally posted by MPH RC
Rod,
Thanks for the well wishes on our travel.
I see you found your glitch problem. Any insite for us Evo rookies in case we experience the same?
BTW, what color car are you going to choose for the KOH race? (It worked for Garber.... lol)
I read we can only purchase 5 sets of B's. Is this true? Will B2's work nearly as well? Are B2's available? What about A's? A guy needs to practice with something. Tamiya has not been shipping tires for the last three weeks and I have not been able to get any for practice. Does RCTech have tires?
Marty
( CYA Monday Morning at 7:00 am)
Hey Marty what's a happening?
The glitching was fixed by replacing my 75mhz synthesized "dial-a-crash" components with a Futaba module and HRS receiver. The one that I'm using is on loan so I have to find my own soon
KOH yikes...don't do this to me. How about you? If I were you, I'd go with Dan's suggestion and use the Mitsu...then the white Acura.
Tires are gonna be hurting if you can only pick up 5sets of one-run B's. For practice, I've been using TakeOffs CS27's. They're close, but not quite.
Tomdav-I tried that and many many other things...none worked until I switched my transmitter module. It was interesting because my stuff worked with EVERY motor prior and Fred just showed up to do some testing with the 23 turn to make sure they're okay and his worked fine straight out of the box.
I hope this helps.
Rod C
rtypec is offline
Old 09-21-2003, 09:40 AM
  #289
Neil Rabara's Avatar
So in other words, you went to a different band.
Neil Rabara is offline
Old 09-21-2003, 10:00 AM
  #290
Rod I hadn't thought of that.
At Reedy I was having some of the glitch on my 3PK but was using the Module from my 3PJ. I switched to the 27and HRS and no glitch I haven't switched back since, the bonus of the servp response with digital is awesome.
Marty bring the 27's for early practice and use the B's starting friday. Like Rod said they will be one run wonders, the second run will notice .2-.4 drop. If the temps are up it can be even worse
Difuser is offline
Old 09-21-2003, 10:05 AM
  #291
Trader Rating: 28 (100%+)
Post 5 B's
So am I to understand that they are allowing us to purchase 5 sets...or will be be able to use only 5 sets for the weekend?
madjack is offline
Old 09-21-2003, 10:20 AM
  #292
rtypec's Avatar
From what I understand it's five sets that you can purchase from Tamiya to do as you please.
rtypec is offline
Old 09-21-2003, 10:53 AM
  #293
How did the B's do on Sat?
Old 09-21-2003, 07:47 PM
  #294
Trader Rating: 27 (100%+)
....there is also a 2 motor allowance only for GT1.....
MDawson is offline
Old 09-22-2003, 06:34 AM
  #295
rtypec's Avatar
F201 B's or Sedan B's? You already know about the sedan B's...one run wonders.
rtypec is offline
Old 09-22-2003, 09:12 AM
  #296
OSherman's Avatar
Thumbs up
F201 B's were terrific...lasted the entire 5 mins...and then some..
anyone know if wheels will also be available at the race this weekend?...hope so.. and if anyone can pass the word the powers-that-be, I would like to have the Williams type wheels..
a side note.. ran against a fellow running the spec motor fo the race.. I was impressed with the power coming out of that thing..
OSherman is offline
Old 09-22-2003, 09:55 AM
  #297
The sedan b's are one run, but the F201 b's can last quite a bit longer. I was just wondering how effective they were last sat.
Old 09-22-2003, 10:09 AM
  #298
gtypecanare's Avatar
All I can say is
gtypecanare is offline
Old 09-22-2003, 11:47 AM
  #299
Originally posted by gtypecanare
All I can say is
All I can say is
Old 09-22-2003, 11:51 AM
  #300
It's speed week ladies and gentlemen. Get your grove on!
