Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 02-16-2024, 07:52 AM
  #22606
Scionara05's Avatar
Originally Posted by Raman
No more Ride 36 for Mini 👍
180 is still honoring them as per there post. Ride xpress and radials are all excepted
Raman likes this.
Scionara05 is offline
Old 02-17-2024, 02:45 AM
  #22607
Three's Avatar
Questions?? Mini tires and insertd
Need some suggestions for the M-chassis class. Only the 54995 Soft and 54999 Hard tires are allowed at TCS races. What tires and inserts should be used on an asphalt surface? Thanks
Three is offline
Old 02-17-2024, 03:37 AM
  #22608
Scionara05's Avatar
soft are going to be what u want but depending on track temps is going to determine the wear. As for inserts i used open cell foam. U are going to have to glue the front side walls for traction rolling. At jackson we use the xpress 30 shore pre mounts. Even for tcs events. I would get with the track and find out what there going to do in regards to tires because tamiya stuff is hard to come by if you dont buy in bulk.
Old 02-17-2024, 10:19 AM
  #22609
Raman's Avatar
Trader Rating: 94 (100%+)
I believe itís the blue soft insert you need. If you have at least a month before your event, Check PlazaJapan for the tyres. I ordered 2 sets of S and one set of H plus inserts and rims from them. Very reasonable prices
Raman is offline
Old 02-21-2024, 08:41 AM
  #22610
Default Finals Site?
With the unfortunate impending demise of Cal Raceway, will we be going back to Omaha for the finals?
jujubean is offline
Old 02-21-2024, 10:29 PM
  #22611
Finals locations shows as TBD at this point.. I say give us all a ticket to Japan.. we’ll run the finals there 😀
jiml likes this.
LordSchnert is offline
Old 02-22-2024, 08:31 AM
  #22612
Scionara05's Avatar
Gte gearing what is every1 doing. Currently have 82x52 installed. Haven't been on the track to know yet just finished my build.
Old 02-24-2024, 09:37 AM
  #22613
Scionara05's Avatar
Is this upper arm setup legal. If not does the ta08 upper arms fit?
Old 02-24-2024, 11:08 AM
  #22614
Raman's Avatar
Shocks, upper arms make that car not TCS legal. Only arms for GTE are legal. TA08 arms are not legal on that car
Dan likes this.
Raman is offline
Old 02-27-2024, 02:23 PM
  #22615
Anyone on here coming to Larry's in Michigan on 3/10? If so, what classes?
GregAnthony is offline
Old 02-28-2024, 07:13 AM
  #22616
f1larry's Avatar
Trader Rating: 22 (100%+)
Not sure yet, if I do I would be running GTE and F1
GregAnthony likes this.
f1larry is offline
Old 02-28-2024, 07:48 AM
  #22617
AKB
Default GT-spec Novice class
Hi. I'm helping my son set up a TT-02R for the novice spec class for the upcoming race at Larry's and I'm wondering if it's legal to add some spacers to the internal part of the shock shaft to add some droop to the set-up? I'd use the the spacers that come on the CVA shock tree and or some 0-rings in the kit. I've read all the rules/regs and I'm not quite sure.
Thanks!
Adam
AKB is offline
Old 02-28-2024, 08:16 AM
  #22618
Raman's Avatar
Thanks!
Adam
Yes for Spec Novice your fine. Youíre allowed hop ups in spec novice, so long as itís Tamiya.. you can even go with TRF shocks
Raman is offline
Old 02-28-2024, 09:48 AM
  #22619
AKB
Thanks!
Good, I just happen to have some NOS TRF special dampers I think we'll build up.
AKB is offline
Old 02-28-2024, 12:20 PM
  #22620
Scionara05's Avatar
Thanks!
Adam
My sons novice car is pretty much a prospec car. You are allowed any esc and can set the car up like a prospec car. U can even gear it faster then the stock 70x20 gear. I have his at 68x27 now and he blows the doors off my prospec car. His is pretty much a tt02r with top adjustable arms.
