Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 01-30-2024, 12:36 PM
  #22576
Scionara05's Avatar
Originally Posted by PROMODVETTE
I would think 3.4 and 3.14 would prevent moving the body post from intended locations.
3.4 It is forbidden for the hobbyist to re-engineer, or alter the car, in any way other than with Tamiya Hop-Ups, or kit supplied accessories.
3.14 You may alter the car in any way called out in the “car instruction manual”, or “chassis setting sheet”. If the “chassis setting sheet” calls out the adjustment, then it’s legal to make the change to your car.
most bodys have dimples you can use for body post on the bumper. And if using a tamiya part u can obviously tell its not a modification because there is a provision on the front bumper for them.
Scionara05 is offline
Old 01-30-2024, 12:40 PM
  #22577
Trader Rating: 70 (100%+)
Originally Posted by f1larry
I just sent an email to Fred to get the final word on the legality of this.
Same, so if its legal to build outside of how the manual states then this would also be legal.
PROMODVETTE is offline
Old 01-30-2024, 12:46 PM
  #22578
Scionara05's Avatar
no this would not. I specifically asked about this to 1 of the coordinators for the Jackson tcs and was told out right no. Not legal bumper post is fine tho.
Old 01-30-2024, 12:56 PM
  #22579
What rule did they cite as to why one is legal and the other is not? Its should be in black and white what are considered hop ups and what are not.
Old 01-30-2024, 12:57 PM
  #22580
Scionara05's Avatar
the rear of the car was not designed with those parts being used in the rear but the front bumper was designed with the front body post in mind. That's why many bodys have dimples in the bodys already for the foward most body mou t
Old 01-30-2024, 01:01 PM
  #22581
Raman's Avatar
Trader Rating: 94 (100%+)
Again the kit has pre drilled locations for 90° body posts. The posts are sold in a parts package.
The stock kit has 0° rear toe. The hop up parts give you 2.0° and 2.5°
These parts are not sold in a hop up package. These are parts put together ad hoc to create ARS. This is adding variable degrees of rear toe control and active rear toe.
Raman is offline
Old 01-30-2024, 01:30 PM
  #22582
angrymelon's Avatar
Thank you to those checking directly with Tamiya, as I am very excited to find out the official decision. I've been wanting this, probably like many others, so that any body I mount on my GT Pro Spec car I can also use on my GT2 chassis (TA07) and vice versa. Unfortunately, I've already drilled two new bodies for existing TT02 front body posts, but if for future bodies I can start using those bumper mounted posts, I'll be ecstatic!
angrymelon is offline
Old 01-30-2024, 01:31 PM
  #22583
These parts are TT-02 specific parts and part numbers where as the body posts are not. You are also not drilling any new holes for the ARS mod either.
Old 01-30-2024, 01:39 PM
  #22584
angrymelon's Avatar
I wonder if its purely based on the chassis having intentional accommodations for bumper mounted body posts, versus someone's clever idea (ARS) that Tamiya hadn't considered. I agree with you on the rules part, as I read it the same way you did that the kit needed to be built according to the manual. Sure it doesn't account for all hop-ups, but every hop up replaces an existing part in the same location, where the body post is different. I'm looking forward to the official answer!
Old 01-30-2024, 02:17 PM
  #22585
f1larry's Avatar
Trader Rating: 22 (100%+)
Fred's Reply to my email
Fred Medel
to me
3:37 PM (38 minutes ago)
Hello Larry,
The short answer is yes. You may mount the post on the bumper or the shock tower. The manual to most TT-02 spec cars show this as an option.
Hope all is well with you.
Fred
Fred MEDEL
Tamiya America, INC.
Marketing Manager
Raman, angrymelon and Scionara05 like this.
f1larry is offline
Old 01-30-2024, 02:22 PM
  #22586
Hopefully we get the same answer LOL! I did go back and look and skipped over this the first time
3.3 Any Tamiya Hop-Up Option and spare part is allowed, if it’s used in the way it was designed and installed on the vehicle it was designed for.
Edit: Thats unfortunate that is his official answer as there are no TT-02 manuals (unless I missed it in the base model, R, RR, or SRX manual) or part number that show that as an option.
Old 01-30-2024, 02:55 PM
  #22587
Raman's Avatar
Mystery solved
f1larry and angrymelon like this.
Raman is offline
Old 01-30-2024, 02:56 PM
  #22588
angrymelon's Avatar
Mystery solved
That's a Type-S manual, which I would've never seen Great find though, I checked all of my manuals and couldn't find what Fred was alluding too.
Raman likes this.
Old 01-30-2024, 03:04 PM
  #22589
f1larry's Avatar
Mystery solved
Glad you took the time to look for the manuals that have that placement, I did not feel like looking right now. I did my work by getting the definitive answer from the man in charge.
Thank you,
Raman likes this.
f1larry is offline
Old 01-30-2024, 03:10 PM
  #22590
Its very washed out on Tamiya's site so I didn't catch that.... but I did catch this
15.1 Legal chassis platform: TT-02, TT-02R, TT-02RR kits only. Note: TT-02 Type S kits are not legal for this class, nor TT-02 Type S specific Hop-Ups. Any TT-02 Hop-Up Option is allowed with the 2 exceptions listed in RED: No aluminum shocks. No carbon shock towers.
angrymelon likes this.
