Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 06-07-2023, 02:56 PM
  #22516
Raman's Avatar
Trader Rating: 94 (100%+)
Originally Posted by quantum
If thats the rule, fine. But am I the only one who finds that odd? because the battery stay is not performance enhancing, it just holds the pack in. If there were a tamiya part that was designed for that purpose then we'd just use that. Generic screws and turnbuckles are allowed. In fact you could argue that lightweight, titanium, hardware has more of an impact on performance than a piece of plastic that simply avoids (and is heavier than) tape!
So is that the official rule from FMW? or is that our collective, educated assumption?
section 3 Vehicle Chassis
https://www.tamiyausa.com/media/file...s-962-7010.pdf
Raman is offline
Old 07-16-2023, 12:52 PM
  #22517
In the formula one class is it required to use a Tamiya servo saver?
alphacat is offline
Old 07-19-2023, 04:48 PM
  #22518
I believe it is under the general rules before or prior to the sub rules and categorys so yes.
id have to go and double check
-Devin
MonkeyCmonkeyDo is online now
Old 07-19-2023, 09:02 PM
  #22519
-Devin
Thanks!!
alphacat is offline
Old 08-19-2023, 10:38 AM
  #22520
Heads up to everyone. The sign-ups are open for TCS Finals in Omaha. September 23rd & 24th. Hope to see you there.
SparkyMAH1971 is offline
Old 08-22-2023, 09:30 AM
  #22521
IndyRC_Racer's Avatar
Does anyone have experience racing in the GT PRO Spec class?
- Was the racing close/fun?
- What are the bare minimum upgrades needed (besides bearings & oil filled dampers)?
IndyRC_Racer is offline
Old 08-22-2023, 11:20 AM
  #22522
Raman's Avatar
Extremely fun, close racing! I’d recommend
1. adjustable RR arms for camber
2. rear toe up rights
3. Oil filled diffs
4. diff locker or spool (new part not sure if it’s been added to approved list)
Raman is offline
Old 08-22-2023, 12:02 PM
  #22523
Here is a link to the rules...https://www.tamiyausa.com/tcs/rules/
FYI:
The last article 24 is addendums which added the Porsche 911 GT3 (992) to GT Pro Spec (8/21/23)
NutDriver likes this.
Old 08-24-2023, 11:05 AM
  #22524
Suspended
Trader Rating: 76 (100%+)
Looking to make the flight to Omaha for the final. I have never raced in a TCS race. ( Raced in a lot of other big time races ). I have a TB-03 I will be bringing.
SPEC Motor rules: Participants in this class must use the REEDY SONIC FT fixed timing, 17.5/21.5 motors. Item #’s 293 & 297 respectively. See the TCS Location Motor Matrix to see what turn motor is used, for each event. 11.4 No BOOST ESC (Electronic Speed Control) rules: Any ROAR legal, and approved, ESC may be used, capable of “Blinky-Mode”. These ESC’s must not use electronic timing (boost). See General Rules for ROAR approved “blinky” ESC list.
Which motor are they running in this class for the final?
Metalsoft is offline
Old 08-24-2023, 12:49 PM
  #22525
I am assuming you are asking about the GT-2 class?
For Finals in Omaha that would be the 21.5 motor.
Old 08-24-2023, 01:06 PM
  #22526
Suspended
Excellent thank you. I wanted to verify before I started purchasing
Old 08-24-2023, 01:08 PM
  #22527
Suspended
What FDR are you guys running?
Old 08-24-2023, 02:38 PM
  #22528
I was around 3.3 - 3.2 FDR running in GT-2 in Omaha a couple weeks ago.
Old 08-25-2023, 10:37 AM
  #22529
Core Creations's Avatar
Trader Rating: 108 (100%+)
You might double check the rules. I believe for finals you have to have competed at a sanctioned TCS event in the class you want to run either in the 2022 or 2023 season.
Core Creations is offline
Old 08-25-2023, 04:10 PM
  #22530
I was off by a year (I think they adjusted it)
