Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 03-09-2023, 08:56 PM
  #22486
Anyone have a couple FT 21.5 motors for TCS? I need two for mini class.
DM me.
EB Racer is offline
Old 03-10-2023, 03:11 PM
  #22487
Hello,
Noobie here...planning to join TCS Pro-Spec this year and I just have a question regarding 'Article 7: Motor Rules', specifically about installing fan/s:
  • How are we supposed to install fan/s for the motor? Are "bolt-on, off-brand, after-market fan mounts that bolt around the motor circumference" allowed?
  • Are 3D designed/printed fan mount/s for the motor permitted?
Any help and/or clarification are most appreciated.
Thank you! =)
kokoyang is offline
Old 03-10-2023, 06:27 PM
  #22488
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by kokoyang
Hello,
They have been in the past. That's what I've always used.
I'm not sure why not. If you did something super out of the ordinary it might get you nabbed, but probably not.
CraigMBA is offline
Old 03-13-2023, 09:10 AM
  #22489
Thank you for the response...someone on a separate thread suggested the kit-supplied plastic part. Apart from it not looking very optimal, it only accepts 30mmX30mm fan...I'd like to know how/what they would allow to mount a 40mmX40mm fan.
Thanks again! =)
kokoyang is offline
Old 03-29-2023, 01:18 PM
  #22490
Default TT02 Front Uprights
Hello,
For ProSpec class in TCS in California, is it allowed to grind the steering limiter in the front uprights?
Thanks in advance =)
kokoyang is offline
Old 03-29-2023, 04:14 PM
  #22491
Raman's Avatar
Trader Rating: 94 (100%+)
Hello,
No grinding allowed whatsoever. You also donít need more steering throw in ProSpec. So donít over think it
Raman is offline
Old 03-29-2023, 07:38 PM
  #22492
Thank you...my car is suffering from grave understeer...any suggestion/s is most appreciated =)
Thank you =)
kokoyang is offline
Old 03-29-2023, 10:36 PM
  #22493
WhiteLX's Avatar
Thank you =)
Are you running a locker or putty in the front diff? What is the current suspension and diff setup? When is it understeering, corner entry, mid, or exit?
WhiteLX is offline
Old 03-30-2023, 07:54 AM
  #22494
Thank you =)
Car is a TT02RR:
Diff: 3K both front and back
Shocks: Tamiya 400 (40 CST?); no droop spacers
Shock Mounting: inner mounting on shock tower for both front and back
Camber: 2 deg front; 1 deg back
The car is "pushing", understeering mostly on exit. However, I won't mind having more steering on entry and mid corner as well.
Thanks for all your help and/or suggestions =)
kokoyang is offline
Old 03-30-2023, 08:17 AM
  #22495
WhiteLX's Avatar
Start with 3mm spacers in the front shocks and 2mm spacers in the rear shocks. Try that first then start increasing the front diff fluid. I run a front locker in mine.
WhiteLX is offline
Old 03-30-2023, 09:29 AM
  #22496
Got it...will try that...thanks for your help =)
kokoyang is offline
Old 03-30-2023, 11:08 AM
  #22497
Raman's Avatar
also move front shocks to outer hole. Swap camber around.. 1į front 2į rear.
What springs are you using?
Raman is offline
Old 03-30-2023, 03:25 PM
  #22498
Hello,
Thanks again for the ideas =) Will definitely try them.
Currently, I have silver/7 coil springs for the front with red (soft) springs for the rear.
Thank you =)
kokoyang is offline
Old 04-15-2023, 11:41 PM
  #22499
CraigMBA's Avatar
In 2013 and 2014, the 2005 and 2008 NSX was legal.
In 2015, it was NOT LEGAL any longer for reasons that aren't really important.
The question was posed on the Facebook group and someone said the early NSX is legal again.
So, is it legal? Because if it is I don't have to paint.
CraigMBA is offline
Old 05-16-2023, 05:40 AM
  #22500
Csaari77's Avatar
Trader Rating: 35 (100%+)
Is there a plan for an alternate motor if the Reedy FT 21.5 isnít back in stock or are we just screwed?
Csaari77 is offline
