Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 06-14-2019, 06:37 AM
  #21991
Thanks for your help. Let me answer questions one by one:
First, I meant that I was slow against other Minis. In the other classes I raced I did not see this differences in top speed (GT Pro Spec, Eurotruck and FWD)
Second, I was using the following:
- Battery: Gens Ace 6000mAh 2S1P 70C full size with Dean connectors (very heavy battery @304g), one year old
- ESC: Hobbywing Justock XR10 (green light was on on full throttle, seems it is properly calibrated)
- Car weight was around 1380g (heavy for the class)
- Bearings: Fast Eddy non sealed, used one race. Non lubricated
- Motor: brand new Reedy 21.5 FT
Differential: TA-03, tight
Regarding turn exit speed, i understand it can be a reason, but the car was toping out max speed at mid straight. Even though the car was heavy, acceleration was comparable to that of other cars. Really did not have this problem in any the other classes (Including GT Pro Spec, that uses the same motor in TCS with controlled FDR)
Last year I had issues with the sensor cable of the ESC, but I checked it and seems fine. Is there any way to check if this is the issue?
Finally, the only reason I talk about changing FDR is because three different people came to me saying that I had to reduce the size of the spur, and encouraged me to do my research on how to do so, stating that the rules only fixed 20t for the pinion, not saying anything about the spur. I disagree with this statement by the way (TCS rules say that internal gears cannot be modified)
The main sin of the car is that it is heavy. For next race, I'll shorten cables, use short battery and change screws to titanium. That should allow me to hit the min weight...but that should help with acceleration and not with top speed.
This is still a mistery to me
Again, thanks for your help
Euroguybrush is offline
Old 06-14-2019, 09:20 AM
  #21992
AngryRog's Avatar
Trader Rating: 20 (100%+)
There are a few reasons right there for the rude awakening. I'll let the others finish it, as I'll get crapped upon again. Haha
AngryRog is offline
Old 06-19-2019, 02:19 AM
  #21993
Warner62's Avatar
I like to watch this type of champion series.
Warner62 is offline
Old 06-19-2019, 07:56 AM
  #21994
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Tamiya M08's have started shipping.
What is the status of the car for TCS? (gearing? anything else?)
Dan is offline
Old 06-19-2019, 10:01 AM
  #21995
Seems good to me. 80g is.. a lot. But it shouldn't really alter top speed. ESC cables are cheap, swapping one out, is a good plan.
[quote]Regarding turn exit speed, i understand it can be a reason, but the car was toping out max speed at mid straight. Even though the car was heavy, acceleration was comparable to that of other cars. Really did not have this problem in any the other classes (Including GT Pro Spec, that uses the same motor in TCS with controlled FDR)
You can use a DMM to check the wires, but it's multistrand and such, so you can't really trust results once you move the wire at all. $8 for 3 cables on amazon.
now... this is bugging me. If people are talking abuot changing FDR. (change the size of the spur) well... there are high speed gears available for the M05/06 chassis.
for M05, Fast Gear Set ,(M05-02) by 3Racing
3racing also sells a differential that's a tooth smaller, providing an even greater speed boost.
It sounds to me, like ~they~ are running non-tcs gears, if they're suggesting that the change is possible. I strongly suspect that this is the case.
With a TBLE-02, and a 4000mah battery, I was 20g under-weight. How you're 80g over is...a bit of a mystery to me.
Nerobro is offline
Old 07-11-2019, 09:51 AM
  #21996
Core Creations's Avatar
Trader Rating: 108 (100%+)
Nats info...rules??
Core Creations is offline
Old 07-11-2019, 01:45 PM
  #21997
NutDriver's Avatar
Trader Rating: 30 (100%+)
And if someone is looking for a GT2 car, I have a couple I'd like to get rid of.
Scott
NutDriver is offline
Old 07-15-2019, 07:54 PM
  #21998
Trader Rating: 93 (100%+)
Markus is offline
Old 07-29-2019, 05:18 AM
  #21999
g12314's Avatar
Originally Posted by Core Creations
Nats info...rules??
+1.
What GT1 / GT2 tires for Nats? Rules say type C, but “this may change”
g12314 is offline
Old 07-29-2019, 08:56 AM
  #22000
Originally Posted by g12314
+1.
Nats rules say Type C...no number limit and you can bring your own.
Old 07-29-2019, 01:53 PM
  #22001
g12314's Avatar
Thanks. I looked at the .pdf of the rules yesterday and it was not updated to what you stated.
g12314 is offline
Old 08-02-2019, 05:27 PM
  #22002
trf415msx's Avatar
Trader Rating: 24 (100%+)
Default TCS final
Hi
is that legal to run M08 at TCS final
thank you
trf415msx is offline
Old 08-02-2019, 06:27 PM
  #22003
MD
MD's Avatar
Trader Rating: 136 (100%+)
Originally Posted by trf415msx
Hi
thank you
This a quote from the rules. But, I would call or email Tamiya,
  1. Legal chassis platforms: M05, M05 V2, M06, and M-07 platforms only.
MD is offline
Old 08-06-2019, 02:08 PM
  #22004
Can someone post the link to the 2019 TCS finals rules. I deleted that email by accident. Also, is the M08 Legal for the Finals?
Markus is offline
Old 08-06-2019, 02:59 PM
  #22005
MD
MD's Avatar
MD is offline
