Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree839Likes
Old 06-07-2019, 08:43 AM
  #21976
Herc Driver's Avatar
So I was dusting off my M04 and found out it’s illegal now? What happened? I’m military so I don’t get to do this every year, but have fun when I get a chance too....was/were there certain cars outlawed for this year?
Herc Driver is offline
Old 06-07-2019, 10:29 AM
  #21977
MarkBrown's Avatar
Originally Posted by Herc Driver
So I was dusting off my M04 and found out itís illegal now? What happened? Iím military so I donít get to do this every year, but have fun when I get a chance too....was/were there certain cars outlawed for this year?
The M04 has been illegal for TCS since 2011 at least (that's the oldest set of rules I could easily dig up). The M03 became illegal in 2017. The M03 was still competitive when they took it out, but certain parts such as swaybars had become unobtainable. It causes bad feelings when racers are getting beat by a car that they can't buy.
It is hard for me to get worked up about a car having "only" a 10+ year lifespan, when in ROAR racing cars can become outdated every year or two and motors faster than that.
MarkBrown is offline
Old 06-07-2019, 05:20 PM
  #21978
Copy...thanks for the info, didn’t know they did this. You’re right though I have had it a while, testament to how solid of a car it is. Wonder if they’d consider a vintage class for us cheapskates holding onto older chassis.
i guess it’s been quite a while since my last TCS race...lol
cementsurfer86 likes this.
Old 06-07-2019, 10:43 PM
  #21979
What's been the tire for outdoor F1 this year? I was told it was TCS rear and kit front? New to F1 and just trying to figure out a starting point.
Hopscotch is offline
Old 06-08-2019, 11:05 AM
  #21980
robk's Avatar
Trader Rating: 22 (100%+)
That is what works 95% of the time. Sometimes some guys get the pit shimizu front to work if there is enough grip. Best to start with kit fronts.
Hopscotch likes this.
robk is offline
Old 06-08-2019, 05:41 PM
  #21981
Though for TCS races I assume the shinizu's are not legal or did they change that rule?
Old 06-08-2019, 10:52 PM
  #21982
F N CUDA's Avatar
Trader Rating: 34 (100%+)
The TCS F1 tires are Pit Shimizu 571 front and 572 rear.
Tamiya kit fronts and TCS/572 rear for the win. (on asphalt)
TCS front and rear for carpet.
F N CUDA is offline
Old 06-09-2019, 09:34 AM
  #21983
mike.a's Avatar
Questions??
Originally Posted by FMW
So is this method legal on mini tires too?
definitely should be
mike.a is offline
Old 06-11-2019, 12:48 AM
  #21984
Great times at HobbyTown Fresno last weekend.
I ended the race with a big doubt though. I found that my Mini M-05 was much slower than other cars on on the super long main straight. Not just a bit, but to the point that being rear ended at high speed was a risk. I was running the 21.5 Reedy FT motor with the largest pinion allowed by rules (20T) and the standard spur. The delta on speed was so large that I doubt it was related to ESC/Batteries
Is there a way to reduce the FDR of a M-05? Are there smaller spur gears available for the mini? I wasn't able to find any Tamiya hop ups for this
If FDR cannot be lowered, does anybody has any ideas on what can be the issue of my car?
thanks!
Euroguybrush is offline
Old 06-11-2019, 08:34 AM
  #21985
AngryRog's Avatar
Trader Rating: 20 (100%+)
It's not your chassis choice per-se, though the 07 is a better platform, IMO. You won't get any real help here on the net. Stick with Mini long enough, the kind information you're needing will eventually be learned or passed on.
AngryRog is offline
Old 06-13-2019, 09:12 AM
  #21986
You're perpetuating the problem. Do better. Do better by your fellow drivers. Mentioning the M07 is a red herring. Saying "you just need to put in the time, and someone will help you" isn't useful either.
thanks!
Well, lets answer a few questions first. Are we talking "all the other cars" or minis? So i'm going to assume you're talking "versus other minis". But to cover the other eventuality, the Mini's are a lot slower than any other 21.5 powered cars.
The M05, M06, and M07 all have essentially the same gear ratio, so should go about the same speed on straights. Lets cover the basics: What battery are you using? What ESC? What's the car weigh? Bearings? If you change the FDR, the car is no longer TCS legal. The "point" is that the gear ratio is fixed.
The ESC could be a problem if the calibration is wrong.
Post a few pictures of your setup?
While we're at it, this is the mini thread: Tamiya mini cooper
Nerobro is offline
Old 06-13-2019, 10:38 AM
  #21987
dmcguire's Avatar
Trader Rating: 38 (100%+)
Like Nerobro is getting to, there really is so much into the prep of a car that it's most likely not the fact that you're running an M05. New batteries and a GOOD motor will be a significant help, but don't forget that bearing and diff prep is huge in Mini.
Are all your bearings new and/or in good shape? Did you clean the grease out and use very light oil? And in most cases a very tight diff is going to help you carry more corner speed.
At my local TCS race I cleaned and oiled the bearings in my new M07, drove very well, but was still slower on the straight than the fastest guys at my local TCS race. My batteries are 3 years old and I bought A single FT 21.5, pulled it out of the box and ran it. I knew I would be at a disadvantage to the guys who had new(er) batteries and had bought several motors, tested them, moved the rotors/sensor boards/stators around and tested more. Doing this you can most likely be able to make a "best motor out of the bunch". I'm sure you'll see a performance increase.
Another thing usually overlooked when it comes to judging straightaway speed, especially with these slower minis is how was your entry line? If you don't have a good run coming onto the straight and the racer behind you does, they are going to be significantly faster than you on the straight. Granted you said it was a long straight, but their run-up to top speed will still be sooner and they'll seem faster. The better batteries and motor will be more apparent towards the end of a super-long straight.
The MO5 is still a good car, and as Nerobro said above, theoretically should have roughly the same top speed due to the same gear ratios.
Go through the car checking everything, reset the ESC and DRIVE. After that, better batteries and motor(s) should be your next step. The electronics can always transfer over to an MO7 chassis if you go that route, but you'll still end up with a slow MO7 if you don't take the proper preparation steps. Mini is a class that should above all be just a blast to drive. Hope this can help some.
Markus likes this.
dmcguire is offline
Old 06-13-2019, 10:43 AM
  #21988
Core Creations's Avatar
Trader Rating: 110 (100%+)
Nailed it...clean bearings and the biggie...entrance into the straight. The sooner the car is setup coming onto the straight the faster the car will seem. You will get that (he’s running over me at the end of the straight) comments when the fast driver gets the car settled and straight much sooner. Makes a huge difference.
Markus and NutDriver like this.
Core Creations is offline
Old 06-13-2019, 08:59 PM
  #21989
AngryRog's Avatar
lol
AngryRog is offline
Old 06-13-2019, 10:36 PM
  #21990
Any Video, Results links from Fresno?
jujubean is offline
