Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 05-08-2019, 04:22 PM
  #21946
spring71's Avatar
Smile
We will have Saturday Club Race on this Saturday, May 11th with Triple Mains.
It will be a great Warm-Up race for TCS Regional on May 19th, next week.
The race will be One 3 minute qualifier, Triple Mains re-sorted by average of 5 fastest laps.
Track will be open at 10am, Race will start at 12pm.
For more information about the track, please visit https://www.tqrcracing.com
Classes & Rule will be the same as TQ Summer series.
6 minute Main
Rookie, Sportsman, Expert, Modified Sedan
USGT
Mini
Euro Truck
8 minute Main
1/12 13.5, 17.5, Modified
F1 Rubber
2019 TCS Regional Race on May 19th registration is OPEN !!
https://www.rccarevents.com/event.cfm?id=2718
spring71 is offline
Old 05-09-2019, 10:59 AM
  #21947
Kevin CBR's Avatar
Originally Posted by Dan
I've seen at least one who have done 3 classes at nationals. If what you said is the case, then it should be enforced.
Rule has been (at least since I started back in 2003) one trip class and one secondary / Exhibition class at Nationals at most. Yes I also saw a person racing three classes within the last couple of years at Nats. No, they were not supposed to be allowed. Yes, it should be enforced.
Panda
NutDriver likes this.
Kevin CBR is offline
Old 05-12-2019, 10:36 PM
  #21948
Originally Posted by honda1
I would like to see no gluing of sidewalls on euro truck
and a ride height spec.
I had a great time
My two cents on this is that glueing any apart of the tires should be unregulated. Without side glue the trucks are not drivable. Even Without top glue the trucks still traction roll just not as easily because after a few packs the sides crack and you get some of the undesired tire bending again... so now I have to glue every time I go to the track to have some consistency. My front tires now have about half the bottle of ca glue whereas if I glued the top first thread i probably wouldn’t even need to glue the sides. There has to be a better way and the only thing I can think of is to remove the restriction altogether, especially since traction is different at all tracks.
ebohon is offline
Old 05-12-2019, 11:06 PM
  #21949
*mumbles something about traction being to high on black carpet, and that black carpet is bad for the sport..*
Troy Carter likes this.
Nerobro is offline
Old 05-13-2019, 07:20 PM
  #21950
F N CUDA's Avatar
Trader Rating: 34 (100%+)
I still don't understand the rule.
It is said that tire gluing could get out of control?
Out of control gluing on the tread would make the tire unusable.
F N CUDA is offline
Old 05-14-2019, 08:16 AM
  #21951
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Not exactly....
All I'm saying is...should be closer tech on the tire gluing on treads. Oops, I've said too much.
Dan is offline
Old 05-14-2019, 08:17 AM
  #21952
Tamiya Euro trucks should only be run on asphalt with no glue on the tires then...The crc carpet tracks won't change soon, and it is obvious that this class will not last long....
bertrandsv87 is offline
Old 05-14-2019, 06:03 PM
  #21953
The Glue on the contact patch will damage the carpet. all that friction will burn it. also, people with lower glue skills have edges on the glue that cut. It is not a HUGe problem just trying to give the other side. Te Euri truck class is not going anywhere anytime soon so we better find a good solution.
jujubean is offline
Old 05-15-2019, 12:26 AM
  #21954
Is the HobbyTown Fresno race really 2 days (June 8th and 9th)?
Landwolf is offline
Old 05-15-2019, 02:19 PM
  #21955
spring71's Avatar
Smile
We will have 2019 TCS Regional Race this Sunday, May 19th.
Track will be open at 8am, Race will start at 10am.
For more information about the track, please visit https://www.tqrcracing.com/
We already have 84 signups so far, it will be a great turnout this Sunday !!
https://www.tamiyausa.com/tcs/schedule/
spring71 is offline
Old 05-15-2019, 03:07 PM
  #21956
Trader Rating: 17 (100%+)
Only can run one Japan trip class for nationals. You can run as many other non-Japan classes (F1, GT Pro spec, euro truck, etc.) as you want.
Thank you Dan
Solara is offline
Old 05-15-2019, 05:30 PM
  #21957
F N CUDA's Avatar
Not likely, it's the largest class at TCS by far
I don't believe that the glue on the contact patch is hurting the carpet, we've been running it like that since day one and show no signs of wear from glue.
If that were the case, the track owners would likely outlaw the glue, no?
The wear holes come from the body posts diggin into the surface when they keep flippin over repeatedly.
We even run glue on the contact patch of the F1 front tires.
Nothing out of control (cuz that would render the tires useless anyway) but enough to take the snap grip roll out of it.
Kevin CBR likes this.
F N CUDA is offline
Old 05-15-2019, 08:01 PM
  #21958
Cycledude's Avatar
I believe HobbyTown Fresno is practice on June 8 and racing June 9.
Cycledude is offline
Old 05-15-2019, 08:22 PM
  #21959
I dont think it is an issue either, just presenting the the possible issue as the spinning of the tire does make a bit of heat, but it takes so much action to do that. anyway, it is what it is and we roll.
jujubean is offline
Old 05-17-2019, 11:18 PM
  #21960
spring71's Avatar
Smile
Food truck will be ready for Lunch this Sunday, May 19th for TCS Regional at TQ RC Racing !!
For more information, please visit https://www.tqrcracing.com/
spring71 is offline
