Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 12-21-2018, 11:25 AM
  #21631
MD
MD's Avatar
Trader Rating: 136 (100%+)
Originally Posted by f1larry
you will not have the 3rd body in your inventory, if you read page 14 there is a new product announcement in regards to the additional body.
Thanks, I am getting old. I didn't read that. I guess it was wishful thinking on my part. I probably won't wait until February. I appreciate the help. I guess I'm eventually going need a large print version. I need all the excuses I can get.
MD is offline
Old 12-21-2018, 12:18 PM
  #21632
Originally Posted by FMW
The RIDE tires we used at the FINALS worked out really well. I really like them. For me it really made the M-Chassis cars a lot of fun to drive in all the test driving I did. We will eventually migrate to them, but I first need to make certain I can supply them consistently.
yes... the mini was a lot of fun driving with the Ride tires, they worked really well and priced right.
Its just the S-Grips are so hard to race on black carpet, not to mention they are expensive.
Now that the racer had to mount there own, the incentive for the racer to accidentally put a different insert is there.
Al Sodano is offline
Old 12-21-2018, 01:10 PM
  #21633
f1larry's Avatar
Trader Rating: 22 (100%+)
Thread started for WCRCís TCS race on March 23rd. Good place to ask questions and get information about the facility and Track.
TCS Windy City Raceway March 23, 2019
f1larry is offline
  #21634
CSeils's Avatar
Trader Rating: 54 (100%+)
2019 Tires for Mini question.
Is there an option to use the Spec S tires (1016) at any of the races?
They are still within rules : S Grips, Spec inserts and Suzuki Swift spoke wheel. That I know of, the only difference is the color of the wheel.
Thoughts?
CSeils is offline
Old 12-21-2018, 01:23 PM
  #21635
f1larry's Avatar
Will the TRF419 aluminum chassis be legal for GT1?
f1larry is offline
Old 12-22-2018, 07:37 AM
  #21636
Trader Rating: 14 (100%+)
I am sure if it has a tamiya part number itís ok
honda1 is offline
Old 12-22-2018, 04:17 PM
  #21637
Thoughts?
Unless something changes,
its pretty cut and dry
Spec tire rules: You must use the Tamiya S-Grip Radial Tire (#53254), Suzuki
Swift white spoke wheel (#51237), and Super Hard Inner Foam (#54590) or Hard Inner Foam (#53255) for this class. Note: You must assemble this specification tire yourself. This is the ONLY tire/wheel/inserts combination allowed for the class. Caution: Assembled tires may not exceed 60MM in diameter!
Old 12-22-2018, 07:14 PM
  #21638
FMW
FMW's Avatar
Correct. It's a clear Hop-Up Option.
FMW is offline
Old 12-22-2018, 07:18 PM
  #21639
f1larry's Avatar
figured it would be.
f1larry is offline
Old 12-24-2018, 09:28 AM
  #21640
MarkBrown's Avatar
Last year's rule was the same as written in the pdf, however Fred amended the rule on this thread to allow the 1016 premounts, and they were allowed in the regionals that I attended. Perhaps Fred will amend the rule again this year? There are still quite a few 1016s out there.
MarkBrown is offline
Old 12-24-2018, 09:39 AM
  #21641
MarkBrown's Avatar
The solder tabs on the Reedy 297 motor look a bit large to fit the opening provided for them in the M07 chassis. Does the motor fit without cutting? Can somebody who has done it provide a photo?
Old 12-24-2018, 09:44 AM
  #21642
MarkBrown's Avatar
Originally Posted by Core Creations
2 new mini chassis to be added to the eligible chassis for mini class....hmmmm
I'm guessing an M08 and a 210mm M07. They teased the 210mm M07 quite awhile ago.
Old 12-24-2018, 10:44 AM
  #21643
FMW
FMW's Avatar
The 1016 Pre-mount may be used if you have them. There's no measurable performance difference between the tire that you have been allowed to build on your own from the 2018 rules and the 1016 pre-mount. In fact, you're better off building your own because you are able to glue the foam insert together. The 1016 pre-mounts insert was not glued together unfortunately. To some that may matter, to others it may not. Anyway, if you have them feel free to use them up.
Merry Christmas Eve to all!! =)
CSeils and NutDriver like this.
FMW is offline
Old 12-24-2018, 11:06 AM
  #21644
The Motors that were supplied at the Nats had the Solder tabs removed for us
no modifications to the chassis were required
motor that was supplied has the same part number
Old 12-24-2018, 12:43 PM
  #21645
CSeils's Avatar
Thanks for clearing that up Fred. Merry Christmas to you all!
CSeils is offline
