Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 07-05-2017, 10:04 AM
  #21046
Johnn27's Avatar
Trader Rating: 89 (100%+)
Questions?? Pre-mounts or not....
Originally Posted by King of B Main
Sweep blue light weight inserts always work good outdoors
Will the pre-mount b3's work as well as the mounted tires with the aqua sweeps? or should I buy tires and inserts ?
Johnn27 is offline
Old 07-05-2017, 11:21 AM
  #21047
tobyzhang's Avatar
Trader Rating: 15 (100%+)
The premounted tires are very good to be honest, you won't gain much if at all for most situations by using another insert. Do take notice that if you want a little more grip and less twitchiness, use a lower profile insert like the sweep regular ones. If you want the car in to be sharper (I think for B3 this is more important on most surfaces) and tire to last a little longer, use the premounted tires or taller inserts like sweep exp aqua or exp carbon.
B3 do not like as much air gap as other tires I noticed and just keep that in mind.
Johnn27 likes this.
tobyzhang is offline
Old 07-05-2017, 11:23 AM
  #21048
tobyzhang's Avatar
Originally Posted by Core Creations
Any word on Nats tires?
No official words yet but we are hoping for Solaris
Old 07-05-2017, 01:16 PM
  #21049
dmcguire's Avatar
Trader Rating: 38 (100%+)
Does anyone know what the inserts' part number is for the premounted B3s?
dmcguire is offline
Old 07-05-2017, 05:39 PM
  #21050
Kevin CBR's Avatar
Tamiya #53582 Medium Insert (green)
Panda 🐼
Kevin CBR is offline
Old 07-05-2017, 06:21 PM
  #21051
dmcguire's Avatar
Panda 🐼
Excellent! Thank you Panda
dmcguire is offline
Old 07-06-2017, 09:36 AM
  #21052
FMW
FMW's Avatar
The 2017 TCS Finals Driver's Manual is live!
https://www.tamiyausa.com/tcs/tcs.php?article-id=554
OSherman and tobyzhang like this.
FMW is offline
Old 07-06-2017, 06:36 PM
  #21053
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Are we allowed to shave a bit of material where the Reedy motor solder tabs hit on the M07?
gigaplex likes this.
Dan is offline
Old 07-06-2017, 08:18 PM
  #21054
F N CUDA's Avatar
Trader Rating: 34 (100%+)
FMW you have a pm
F N CUDA is offline
Old 07-06-2017, 10:11 PM
  #21055
Kevin CBR's Avatar
Originally Posted by F N CUDA
FMW you have a pm
Let me answer that for you Cuda as I already talked to Fred. Yes, you, Dr. Bruce, Anthony, Tyree and Bill all can run F1 at Nats this year. Enjoy my friend as I will be migrating to a different class this year.
Panda
Old 07-06-2017, 10:17 PM
  #21056
Hi everyone..
have people noticed that the newer m05's have poorer plastic quality? i compared my new m05 to an older one and the old one has MUCH better steering tightness compared to mine. (both have bearings in steering links)...unfortunatley our class does not allow any mods to the cars at all....any suggestions? whats a goos bang for buck small bearing to go in the steering thats super tight?
Lunchie is offline
Old 07-07-2017, 12:11 AM
  #21057
gigaplex's Avatar
Wait, the TCS spec motor doesn't actually fit properly in the new car? I've seen others have problems with other motors and I just assumed that they only tested it with the TCS motor.
gigaplex is offline
Old 07-07-2017, 05:21 AM
  #21058
dmcguire's Avatar
The individual class rules are down on the TCS racing web pages.
I found verbiage from 2015 stating that in GT1 class there is no weight limit if using a tub chassis (TA07). Is this still in effect? Even if the GT1 class is running 17.5 and not 13.5?
dmcguire is offline
Old 07-07-2017, 08:52 AM
  #21059
FMW
FMW's Avatar
Yes. That rule is still in effect.
dmcguire likes this.
FMW is offline
Old 07-07-2017, 08:57 AM
  #21060
FMW
FMW's Avatar
Use a .5 or 1.0 motor shim between the motor and motor plate. That will give you the perfect spacing for the Reedy Spec motor. It will also be good for other brands too.
johntrickle2 likes this.
FMW is offline
