Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 07-28-2015, 09:25 PM
  #20056
minidriver's Avatar
Default FWD?
Fred: Must the gear cover be used on the FF03?
Thanks for posting the rules!
minidriver is offline
Old 07-29-2015, 08:15 AM
  #20057
EricP's Avatar
I'll go on record and say the FF class will be an open gear-ratio class. No gear covers will be required for either the FF03 or the FF04. Have fun
EricP is offline
Old 07-29-2015, 08:32 AM
  #20058
FMW
FMW's Avatar
Originally Posted by MarkBrown
Thanks, Fred!
1. The "personal tranponder information" portion of the driver's manual says that MRT transponders do not work at the Tamiya facility. And yes, the original "MRT PTX" model is not RC4 compatible. But the newer "MRT PTX (NS)" model, available for about two years now, is compatible with RC4 decoders. I ran an MRT last year and expect to run one this year unless there is some new issue with them (if so please advise).
The driver's manual steers people toward AMB Hybrid transponders, but given that the Tamiya track has an RC4 decoder, the cheaper AMB RC4 (3 wire) transponders will work. As will the AMBrc and the MRT PTX (NS) transponders.
2. The "M-Chassis class handout motor and pinion gear" section says that a pinion gear will be provided with the motor. The manual should specify how many teeth this pinion gear will have, so racers can ensure that the correct set of motor mounting screw holes is available (and not covered by ballast, a transponder, or whatever).
I do not and will not condone the use of a cloned product. Use MRT transponders at your own risk. M-Chassis racers should make sure their cars are able to accommodate a 20 tooth pinion.
FMW is offline
Old 07-29-2015, 12:21 PM
  #20059
Originally Posted by FMW
Details regarding the 2015 TCS Finals are Now LIVE! Please read them carefully and post any questions you may have here. Sign ups will be open soon.
http://www.tamiyausa.com/tcs/tcs.php?article-id=554
FM
For practice on thursday and friday, will it be controlled practice?
looklikeaflip is offline
Old 07-30-2015, 01:53 PM
  #20060
tobyzhang's Avatar
Trader Rating: 15 (100%+)
Can we trim the molding line on the B3 tires?
tobyzhang is offline
Old 07-30-2015, 02:01 PM
  #20061
katana's Avatar
Trader Rating: 18 (100%+)
The manual mentioned "see Track Facility MAP", is that available somewhere? Or will be posted that weekend?
Thanks,
katana is offline
Old 08-02-2015, 07:07 PM
  #20062
Sunday Aug 2, John Brown from Brownies Hobbies held TCS race 208 at Jackson RC.
Thanks too John Brown and crew for there support and passion for TCS!
Thanks too Tamiya USA for there support also!
86 Entries, 40 minis!
Here are the results;
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Al Sodano is offline
Old 08-02-2015, 07:10 PM
  #20063
some more;
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 08-02-2015, 07:15 PM
  #20064
and;
File Type: pdf
Old 08-02-2015, 07:26 PM
  #20065
BrowniesHobbies's Avatar
Default TCS at Jackson hosted by Brownie's Hobbies
What a great day! 40 entries in Mini! 86 entries in total. Many new racers and first time winners!
Thanks to Al Sodano for the use of his amazing facility. Greg Sharp and Alex Valdez for there award winning announcing.
To my crew I would like to say I couldn't do these TCS races without you.
To all the racers who traveled from far and wide, thanks for making the trip. If not for your participation, these races would not be possible.
BrowniesHobbies is offline
Old 08-03-2015, 08:48 PM
  #20066
Carl Giordano's Avatar
Trader Rating: 32 (100%+)
Thanks to John Brown and his Crew, Al Sodano and the Jackson Raceway Crew, Greg Sharpe for MC and keeping the program running smoothly and thank you to Fred at Tamiya and Tamiya USA for a wonderful program. This is the 4th TCS race I've attended with my sons, Andrew (7) and Michael (6) and we all have a great time. Fantastic event and to have 40 entires in Mini and both an A & B Main for Novice was fantastic. Great to see so many new young faces at the track.
Carl Giordano is offline
Old 08-04-2015, 02:31 PM
  #20067
MikeR's Avatar
FM
Hello Fred,
I was not able to participate this year in TCS but hope to next year. Have had lot's of fun at the Fredtech and Reedy races though
Have you considered adding a 2nd starting grid onto the straight that is double spaced for us mere mortals? Perhaps painted in TRF blue? I think saving the close packed white grid for Reedy invite would be great and then having a 2nd 'blue' grid for us regular folk will enhance racing in the mains (reduce the hairpin pile ups) and put more meaning into qualifying well. Hope that this is something you might consider for the 2016 race season.
Thanks Boss!
MikeR is offline
Old 08-04-2015, 02:59 PM
  #20068
Default TCS finals
Will the track be open for practice Friday August 21st ?
dan22 is offline
Old 08-04-2015, 03:57 PM
  #20069
Yes. Read the driver's manual that Fred posted on this thread
  #20070
katana's Avatar
Short answer is 'yes'. Please check out the link at the top of this page https://www.tamiyausa.com/tcs/tcs.php?article-id=554 Look for link under "2015 TC Finals Dirvers' Manual"
katana is offline
