Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree828Likes
Old 02-22-2015, 02:46 PM
  #19636
maxepower's Avatar
Talking Ferrari 599? Or is it?
Originally Posted by torg
Max ran a camouflaged test mule today...
I grabbed a "spy shot"...
Yes, I tried the body and it handed me fast lap for the day, or coarse it was "happy hour", thanks Torg
maxepower is offline
Old 02-23-2015, 04:26 AM
  #19637
kwkride's Avatar
I competed in TCS Race #200 over the weekend at the HobbyTown HobbyPLEX in Omaha, NE.
Thanks Tamiya for supporting such a great event! It is so much fun, I'm already looking forward to next year.
kwkride is offline
Old 02-23-2015, 05:39 PM
  #19638
Core Creations's Avatar
Trader Rating: 110 (100%+)
I'm curious as to why Tamiya lists GT12 as an active non exhibition class yet doesn't give medals or kits/prizes for top 3 as the other active classes?
Core Creations is offline
Old 02-23-2015, 09:17 PM
  #19639
Default Best kept secret
Max, you just let out the best kept secret. It isn't the fastest, but I like the consistency of that (unnamed) body. Now, shuuuuuushh
EB Racer is offline
Old 02-24-2015, 08:44 AM
  #19640
CSeils's Avatar
Trader Rating: 54 (100%+)
With just a week or two to go, when will registration open for races #201 and #202?
CSeils is offline
Old 02-24-2015, 11:35 AM
  #19641
Trez83's Avatar
I would like to register for the races at Horsham. Where can I do that?
Trez83 is offline
Old 02-24-2015, 01:38 PM
  #19642
FMW
FMW's Avatar
Race 201 and 202 are now open for sign ups.
FMW is offline
Old 02-24-2015, 01:39 PM
  #19643
FMW
FMW's Avatar
You may sign up by clicking the link below.
http://www.tamiyausa.com/tcs/schedule.php#.VOzvcPnF98E
FMW is offline
Old 02-26-2015, 06:36 PM
  #19644
silden's Avatar
Hi,
This will be my first TCS and I have a couple questions to this rule:
3. Any Tamiya Hop-Up Option and spare part is allowed and legal as long as it is used in the way it was designed, and installed on the vehicle it was designed for.
Is it TCS legal when install all hop-up with I find on the Tamiya page for my car or only the once made for specifically for it?
I found that some of the TRF418 suspension parts call as compatible. Would it be legal to use these?
Can I use a alu servo mount from another Tamiya car, because I can't find one for my TA06 pro.
Lat but not least can some one provide me with a Setup sheet for the TA06 pro, because I like to know what will be allowed to change Setup wise.
Thank you for your help
silden is offline
Old 02-26-2015, 07:13 PM
  #19645
MarkBrown's Avatar
Originally Posted by FMW
M-Chassis Racers,
I have uploaded the NEW M05 Version 2 set up sheet here:
http://www.teamtrf.com/index.php/201...ategory/9-m-05
This file is invaluable for two reasons...
1. It will help you track what you're doing to make your car faster and better overall.
2. It basically tells you what is allowed to be changed to meet TCS rules. If you see the set up sheet call a change out, then it's legal to do using Tamiya Option Parts of course.
Hey Fred, just to check my understanding: The setup sheet does not call out 54192 (the M05 aluminum steering rack) as an option, so we can't use that part on the M05v2, correct? It does not call out 54542 or 92238 (M05 rear suspension mounts with toe-in), so we can't use those parts on the M05v2, correct? There are more examples but these should illustrate the issue.
MarkBrown is offline
Old 02-26-2015, 08:12 PM
  #19646
R/C Tech Elite Member
monkeyracing's Avatar
General rule #3 covers that:
"3. Any Tamiya Hop-Up Option and spare part is allowed and legal as long as it is used in the way it was designed, and installed on the vehicle it was designed for."
An M05 is an M05, right?
monkeyracing is offline
Old 02-26-2015, 09:39 PM
  #19647
kwkride's Avatar
Originally Posted by silden
Hi,
Last but not least can some one provide me with a Setup sheet for the TA06 pro, because I like to know what will be allowed to change Setup wise.
Here is a link to TA06 manuals and a setup sheet.
http://www.petitrc.com/reglages/tami...TamiyaTA06.htm
I ran my TA06 last weekend at the TCS race in Omaha.
I have TRF418 suspension arms on mine and it was not an issue.
I can't answer for Fred, but I'm sure that using Tamiya aluminum servo mounts shouldn't be a problem either. I think the ones from the RM01 would work fine.
kwkride is offline
Old 02-26-2015, 10:23 PM
  #19648
silden's Avatar
Thank you for the reply.
silden is offline
Old 02-27-2015, 08:33 AM
  #19649
MarkBrown's Avatar
Aha, your interpretation is that the setup sheet is used to highlight a subset of the changes allowed under rule 3, *not* to restrict the changes allowed. Fred, is that what you meant by saying "It basically tells you what is allowed to be changed to meet TCS rules"?
Old 02-27-2015, 09:41 AM
  #19650
OSherman's Avatar
i knew that was coming..
almost every Tamiya option parts is labeled with what platform it supports/is designed for. we all know that M05 is M05 regardless of wether its vI or v11.. Its not an M03 which has an S-version with a couple bespoke parts.
and yes some M03 options are allowed on M05 altho not labeled (Front Universals and Aluminum front Dogbones.. look it up)
lets just all be gentlemen and participate in the fun of the event. Fred cannot possibly word every little idiosyncrasy of the rule. We have been doing this long enough to know the ins-n-outs and the intention of the series and its rule set. if you get called for it, just simply comply and carry-on.
$0.02
OSherman is offline
