Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree805Likes
Old 02-18-2015, 03:38 PM
  #19606
Originally Posted by rtypec
I was digging through old photos and came across some eye candy for your viewing pleasure
Very nice Rod, just as nice as the new nsx you brought to tamiya last saturday. How long did it take you to paint and apply stickers? I could never line up those sticker..LOL
Danny
fx35rc is offline
Old 02-18-2015, 04:05 PM
  #19607
EricP's Avatar
Originally Posted by KA2AEV
Yes but you cannot run a brushless motor in the spec novice class,
Only the 540, 540Johnson, or the Tamiya Torque Tuned motors
And as for the ESC, you have to run the ESC that comes with the kit!
Look in the rules Eric
I would like to comment on your inaccuracies. First, I made no mention that brushless motors can be run in the spec/novice class. I did, however state that “In brushless classes, the Tekin is legal. For spec/novice, any brushed motor ESC, Tamiya or other can be run… and that if the Tekin ESC has brushed motor capability, it is legal” … which is absolutely true.
I’ll go ahead and copy/paste the rules for the Spec/Novice class. Nowhere in the TCS rulebook does it state that the “kit included” ESC must be run in the Spec/Novice class… PS: I don’t need to look in the rules… I’ve co-written them for the last 5 years.
GT Spec Novice Rules
The GT Spec class is for Novice drivers only. This class is perfect for new drivers that have little to no experience and just getting into RC racing. Intermediate, Advanced and Expert drivers are not allowed in this class.
Skill Level: Novice Only
1. Legal chassis platforms: TT-01, TT-01R, TT-01E, TT-01R-Type E, TT-02, TT02S and TT-02R.
2. The GT Spec class may use any Tamiya Hop-Up-Option designed specifically for the platforms allowed above. Recommended: Ball Bearing set, Speed Tuned Gear Set, Aluminum motor mount and Oil-filled dampers. These 4 Hop-Up-Options are all you really need.
3. The Kit type closed-end-bell, silver can motor (Mabuchi/Johnson) 540-J and RS 540 Torque Tuned motor (items 54358 & 53689) are the only two motor types allowed for this class.
4. You must run the kit type tires included with the TT kits: Example: Racing Slicks (50454), Racing Radials (50419), Racing Semi Slick Tires (50810). These are the only rubber/vinyl compounds allowed.
5. Medium Narrow 24mm tires and wheels are NOT allowed. All Tamiya Spec Class cars MUST use 26mm wheels and tires.
6. Any Tamiya 190 mm GT or Sports car body is permitted.
EricP is offline
Old 02-18-2015, 04:19 PM
  #19608
KA2AEV's Avatar
Eric look at rule number 2
Any Tamiya hop up can be used
Correct me if I'm wrong but Tekin isn't a part of the Tamiya company!
Very good on you co writing the rules, but for all of the tcs races we have ran which
Are many, the track techs go by that rule that if you add anything that is not
Included with the kit, its considered a hop up, and if he changes the esc
That comes with the kit to a better one, is that or is it not considered
A hop up option part then?
KA2AEV is offline
Old 02-18-2015, 04:29 PM
  #19609
EricP's Avatar
Very good on you co writing the rules, but for all of the tcs races we havran which
Yes. You are incorrect, and your track techs are technically not interpreting the rules for that class correctly. Electronics do not fall under "Tamiya Hop-Ups" part of the rules. A "Hop-Up Option" part is a Tamiya branded replacement part for the specific vehicle they are offered for. Every class has something to the effect of "Tamiya Hop-Ups only".
Hop-Ups are option parts, electronics are electronics. By your statement, what you are also saying is that a racer must also run a Tamiya transmitter, servos, receiver... and batteries!.... You and I both know that is wrong.
EricP is offline
Old 02-18-2015, 04:45 PM
  #19610
KA2AEV's Avatar
You're totally correct, but this is the rules that the track techs have been going by
For quite some time, and for all of the tcs races we have ran the only non tamiya
Add on option parts that were permitted in the spec novice class were the receivers and batteries . Even the servos had to be tamiya brand.
If these are the rules you are making, as the person who co wrote the rules
You really should clairify this right away on the web site. Because like I said
This is what the track techs go by!
KA2AEV is offline
Old 02-18-2015, 05:00 PM
  #19611
rtypec's Avatar
Danny
Thanks Danny. The bodies do take a while (about an hour or two for each color) to mask, paint, and finish...but the results (at least with this livery) are worth it.
rtypec is offline
Old 02-18-2015, 05:02 PM
  #19612
rtypec's Avatar
Default Repsol NSX Concept
rtypec is offline
Old 02-18-2015, 05:06 PM
  #19613
KA2AEV's Avatar
Rtypec
It takes you an hour or 2 to do that???
Wow you do really nice work!!!
KA2AEV is offline
Old 02-18-2015, 05:13 PM
  #19614
rtypec's Avatar
Emphasis on each color
rtypec is offline
Old 02-18-2015, 09:56 PM
  #19615
FMW
FMW's Avatar
'RODICULOUS"
Definition: Anything that is presented or done with the utmost precision without consideration of time or monetary expense. "RODICULOUS"
FMW is offline
Old 02-18-2015, 10:04 PM
  #19616
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
Stunning
RedBullFiXX is offline
Old 02-18-2015, 10:12 PM
  #19617
Trader Rating: 41 (100%+)
markpoleon is offline
Old 02-19-2015, 01:23 AM
  #19618
very nice!
torg is offline
Old 02-19-2015, 04:41 AM
  #19619
Kevin CBR's Avatar
Sweet job Rod. Look forward to matching up my Mild Seven NSX Concept to your Repsol version in late March.
Panda
Kevin CBR is offline
Old 02-19-2015, 04:47 AM
  #19620
C5R01's Avatar
Man, Stepping up your game!!!! NICE WORK!
C5R01 is offline
