Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree822Likes
Old 08-13-2013, 10:17 AM
  #18211
bizkit1's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Markus
FF03 21.5 has an open ratio and does not require the gear cover. I let a rookie TCS driver use my FF03 for GT3 and he won the class plastic shocks and all.
Spur: 80
Pinion: 57 - 60
on a track just a little smaller than Tamiya's.
Be sure to use a fan and you'll be in the 140-150 degree range after a 6 min run.
Good luck.
TCS Rules FWD
8. The gear cover MUST be used.
Just incase you go out to Tamiya USA and run in GT3 with this car, you must follow the FWD rules.
bizkit1 is offline
Old 08-13-2013, 10:20 AM
  #18212
SpeedTech's Avatar
Default Premount B3 Tires
Hi Guys,
Just a quick note, this is the last week for our "Early Bird Pricing" on B3 Premount Sedan tires. The price goes back up next week.
I'll also be at the Tamiya track this Saturday (8/17). Let me know what you need and I'll deliver.
Cheers,
Jeff
SpeedTech is offline
Old 08-13-2013, 01:03 PM
  #18213
tiko's Avatar
Trader Rating: 35 (100%+)
Originally Posted by bizkit1
TCS Rules FWD
TCS rules are clear for the FWD cars. He's response was to my question to what or how does this affect the rules if anyone decides to use the 21.5 motor instead of the silvercans. Do we have to go with the same FD of 3.85 and 80-54 gearing, or we have the option of taking the gear cover off to get the right gearing for the specific motor that we're using.
Maybe Fred can clear this question. What do you say Fred?
tiko is offline
Old 08-13-2013, 01:40 PM
  #18214
Hebiki's Avatar
Trader Rating: 26 (100%+)
paging Bruce Hickman..... paging Bruce Hickman... please pick up a white courtesy phone
Hebiki is offline
Old 08-13-2013, 03:18 PM
  #18215
FMW
FMW's Avatar
Tiko,
I can't find the rule you're talking about on our current TCS website. I know I had put in the gear cover rule, but I distinctly remember DJ removed the rule once he took over the series.
As it stands now, you may use your FF-03 without a gear cover and you may gear up to your hearts content. Good luck to everyone this year!
FMW is offline
Old 08-13-2013, 04:35 PM
  #18216
tiko's Avatar
Originally Posted by FMW
Tiko,
Thank you Fred
tiko is offline
Old 08-14-2013, 11:42 AM
  #18217
Trader Rating: 39 (100%+)
I hope everyone has a fun nationals this year. I was hoping to make it and throw my hat into the F1 group, but vacation time has stopped me from doing so. I hope I can say differently next year.
Jamie Hanson is offline
Old 08-14-2013, 02:43 PM
  #18218
Kevin CBR's Avatar
Sir Fred - question on voltage in tech for Nationals. In past, people who were pushing the 8.44 limit and went over were allowed to "discharge" the battery by running the motor in tech until they were back in the limit. What about they just don't get to make that run ? People who are charging over 8.44 know what they are doing and pushing for that little "advantage". If they know they will miss their qualifer (or main), they will stop overcharging which is a safety issue. Hence why we have an 8.44 limit. Thank you for considering....
Panda
Kevin CBR is offline
Old 08-14-2013, 04:35 PM
  #18219
FMW
FMW's Avatar
Panda
I believe Scotty E. has that rule for IIC. I will consider it for sure
FMW is offline
Old 08-14-2013, 04:47 PM
  #18220
FMW
FMW's Avatar
Hello TCS Finalists
I have attached the current TCS Nationals entries. Please take a look at the file. If you see a mistake with your transponder number or if you did not provide one, please PM me and I will add/make the correction.
It's looking to be a who's who for 1/12 scale. With 13.5 power this year the class is going to be off the chain!
File Type: pdf
FMW is offline
Old 08-14-2013, 09:07 PM
  #18221
Leester's Avatar
Trader Rating: 23 (96%+)
Panda
So what's to stop them from over charging in the pits and discharging to 8.44 just before going to tech? Cheaters will always be cheaters.
Leester is online now
Old 08-15-2013, 12:03 PM
  #18222
Kevin CBR's Avatar
Hello TCS Finalists
Looks like 1/12th class is the new past champs class !
Old 08-15-2013, 04:43 PM
  #18223
MarkBrown's Avatar
The other, simpler, possibility is to change the limit to 8.40 volts. The few whose chargers push past this can discharge to 8.40 volts at the tech table. Everybody else can just charge their batteries as usual. Nobody has to wreck their batteries just to keep up.
MarkBrown is offline
Old 08-15-2013, 04:46 PM
  #18224
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
+1
RedBullFiXX is offline
Old 08-15-2013, 05:06 PM
  #18225
cementsurfer86's Avatar
+1
cementsurfer86 is offline
