Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree824Likes
Old 03-25-2013, 03:56 PM
  #17851
Originally Posted by TonyD.
So only silver can motor that comes with the M-05 kit. Is the water breakin meathod a good one for that motor?
You have to run the 540J motor (item# 53689). Personally, I would recommend just a little oil on the bushings and that's it. There is a 18,750 RPM limit and just oiling the bushings and running the motor out of the box will put you pretty close to that as the motor runs in on it's own.
David J. is offline
Old 03-26-2013, 06:06 PM
  #17852
Trader Rating: 19 (100%+)
Here are the results from this weekends TCS race number 179 at HobbyTown in frederick, MD
R4_Race_01_F-1 Rubber_B-Main.pdf
R4_Race_02_Mini Cooper_B-Main.pdf
R4_Race_03_Mini Cooper_C-Main.pdf
R4_Race_04_Mini Cooper_D-Main.pdf
R4_Race_05_GT-2_A-Main.pdf
COLD AS ICE is offline
Old 03-26-2013, 06:07 PM
  #17853
more result. last of them.
R4_Race_06_GT-3_A-Main.pdf
R4_Race_07_Spec Novice_A-Main.pdf
R4_Race_08_F-1 Rubber_A-Main.pdf
R4_Race_09_Mini Cooper_A-Main.pdf
R4_Race_10_GT-1_A-Main.pdf
Old 03-26-2013, 07:48 PM
  #17854
Three's Avatar
Has anyone used the new Tamiya tires (1031, 1032) on the F104 Pro? What changes did you make from using the other Tamiya F1 tires? Trying to prepare for the TCS race. Thanks.
Three is offline
Old 03-27-2013, 06:16 AM
  #17855
Trader Rating: 39 (100%+)
We ran those tires at our TCS race this past weekend. They worked really well. They really seemed to stabilize the car over the normal Tamiya F1 tires. A few people tried different inserts but most just ran the stock insert with great success.....
Jamie Hanson is offline
Old 03-27-2013, 07:58 AM
  #17856
KA2AEV's Avatar
Just wanted to thank Randy, Dave and the crew at Hobbytown in Frederick, MD for running a first class operation in this past weekends TCS
We're actually looking forward to going back for the next one down there!!!
Thanks Guys!
KA2AEV is offline
Old 03-27-2013, 09:44 AM
  #17857
F N CUDA's Avatar
Trader Rating: 34 (100%+)
These tires are money!
They are a direct result of having a Tamiya bigshot (hi Fred ) racing in the UF1 series with us here in So Cal and seeing the performance of the Pit Shimizu 071 and 072 tires which are what finally made these modern F1 cars actual race machines.
The 1031 and 1032 tires ARE the same tires and have the TCS logo on them and were introduced last year.
They work incredible on asphalt and carpet with superior traction on both ends of the car.
Run the rear of the car soft and the front of the car medium to firm.
Carpet sauce em with Jack the Gripper or SXT (careful how much on front tires, 1/2 is common) and for asphalt use Buggy Grip or Tire Tweak. Done deal
F N CUDA is offline
Old 03-27-2013, 06:33 PM
  #17858
Three's Avatar
Thanks. Haven't run the F1 since the 2011 TCS race in Memphis.
Three is offline
Old 03-31-2013, 10:11 AM
  #17859
Leester's Avatar
Trader Rating: 23 (96%+)
So... what is the head count for each class for the TCS race next weekend? Lots' of discussion going this weekend regarding people signing up for Mini Pro (21.5). If you haven't done so and you're interested, sign up!
Leester is offline
Old 03-31-2013, 03:40 PM
  #17860
F N CUDA's Avatar
I switched to slower can, I mean silver can. Response to 21.5 sounded to iffy to me yesterday and as David J stated in a post earlier, if 5 or more sign up on race day he will add the class as an exhibition class but no prizes etc will be awarded.
Maybe next time
F N CUDA is offline
Old 03-31-2013, 06:33 PM
  #17861
Attn: TCS officials. I have a quick question. Do I have to race a regional race to be eligible for this years nats? I heard a rumor that if you made the top (10) at the previous nats you could skip the regionals. But I can't find that rule. Can you clarify this for me. Thanks in advance.
Juan Aveytia is offline
Old 03-31-2013, 07:12 PM
  #17862
jrz93's Avatar
Are there spec tires for each event? Per class?
Was planning on attending Enfield ct and wanted to know what tire to run for gt2?
jrz93 is offline
Old 04-01-2013, 06:00 AM
  #17863
Trader Rating: 94 (100%+)
Originally Posted by F N CUDA
I switched to slower can, I mean silver can. Response to 21.5 sounded to iffy to me. Maybe next time
I was in the same situation. This will probably be an on going theme throughout this season. I predict only one or two venues will host the 21.5 mini class.
I preferred the 21.5 class but the fast mini group of drivers were using silver cans and that's who I wanted to race against... so silver can it was.
^^^JRZ there is a spec tire:
Premounted B3 Type Tires 24mm TCS Spec tire. Tamiya #1015
Markus is offline
Old 04-01-2013, 04:24 PM
  #17864
Juan, you must have participated and made the top 10 in a regional event during the season or prior season in order to participate in the Finals. So if you participated in the 2012 finals but hadn't run a regional since 2011, you have to participate in a regional this year to run in the 2013 Finals. How many regionals?... Just Juan...
David J. is offline
Old 04-01-2013, 04:34 PM
  #17865
TonyD.'s Avatar
Trader Rating: 43 (100%+)
got jokes. very funny LOL
TonyD. is offline
