Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree818Likes
Old 01-09-2012, 05:48 PM
  #16636
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Originally Posted by FMW
Hey guys.
Sorry for all the confusion on the spec tire thing for Mini. For now, Mini guys will have three pre-mount tires to chose from. The S-grips and two "A" compounds which are mounted on a firm and soft insert. You may use these on any regional track regardless of surface.
If all goes well the three choices should offer all of you a decent set up. If things get messy this year we will re-evaluate the rule and adjust. The Mini Type A should be available shortly in time for the first regional race. They are being bagged as we speak....
On another note: check out our newest announcement regarding what the 2012 trip classes will be and a new wrinkle.
http://www.tamiyausa.com/tcs/tcs.php?article-id=556
Happy New Year
M-Chassis classes must use the Spec 60D Pre-mounted tire sets available. Items: 1016 (Super Grip Radial w/foam insert-firm), 1028 (60D Type-A w/foam insert soft) and 1029 (60D Type-A w/foam insert hard) All tires are mounted on Suzuki Swift wheels.
Hi Fred,
Above I copied the tire rules for Mini from Tamiya's site.
It is noted that "M-Chassis classes must use the Spec 60D Pre-mounted tire sets available."
Does this mean that full "sets" must be used or will we have/get to mix and match?
F N CUDA is offline
Old 01-09-2012, 05:52 PM
  #16637
over gear's Avatar
Trader Rating: 18 (100%+)
"If a former TCS champion wins the GT-1 class they are not eligible to compete again for another two years. New winners must also sit out the TCS Finals for two years to be eligible to compete again."
so , what happen to the 2010 and 2011 GT1 Champ?
over gear is offline
Old 01-09-2012, 06:50 PM
  #16638
OSherman's Avatar
Thumbs up
Surprising wrinkle indeed.. i like it!! GoodLuck to all!!
OSherman is offline
Old 01-09-2012, 08:00 PM
  #16639
JasonC's Avatar
Trader Rating: 120 (100%+)
Originally Posted by MDawson
I like the wrinkle. All in!
Planning a road trip
JasonC is offline
Old 01-09-2012, 08:02 PM
  #16640
RedBullFiXX's Avatar
There is a lot on the line to motivate folks to step up and run GT1.
Good job Tamiya
RedBullFiXX is offline
Old 01-09-2012, 08:52 PM
  #16641
Laguna Bozo's Avatar
Mini, meaning silver can or brushless?
Laguna Bozo is offline
Old 01-09-2012, 08:53 PM
  #16642
Looks like Brandon will have to borrow a car for GT1. . .
A-Ko is offline
Old 01-10-2012, 12:07 AM
  #16643
Kevin CBR's Avatar
Henry, that rule only applies to "Trip winning" class Champions. You are eligible to race for the trip this year because GT-1 was only a "National Class" in 2011. For 2010, there was no GT-1 class.
Kevin CBR is offline
Old 01-10-2012, 12:10 AM
  #16644
Kevin CBR's Avatar
Good job Tamiya
Good chance that "$500 prize" could be a new 417 and the cash for new electronics to take a new ride to Japan. Also gives us "non-past Champions" incentive to take on the uber fast guys for a chance at fame and glory. At least I know I am already planning to run in 3 of the 4 trip classes this years regionals so only question come August will be which one to pick.
Old 01-10-2012, 07:33 AM
  #16645
Trader Rating: 28 (100%+)
Good job Tamiya
excellent idea, should be very entertaining to watch!
madjack is offline
Old 01-10-2012, 09:37 AM
  #16646
FMW
FMW's Avatar
The sitting out rule begins after we crown a new GT-1 winner in 2012. Meaning...Anyone who won GT-1 in the last 2 years does not need to worry. You don't have to sit this years Nationals out.
Cuda, you may mix and match Mini spec tires if you wish. Based on what I have seen, the Type A's should be a great tire on carpet TCS races while the S-Grip should be your best choice on hot asphalt surfaces. However, I'm sure people will experiment a little to see if they can find a combo that will make their poorly set up Mini drivable
FMW is offline
Old 01-10-2012, 09:44 AM
  #16647
FMW
FMW's Avatar
Bozo,
Whether you race in Mini "classic" or Mini "Pro" it will qualify you for the TCS finals.
I would like to see how Mini Pro works out in the coming races, but right now I'm leaning on our current TCS Finals formula with hand out Johnson's. It's worked out well and it's fair.
I'm sure there will be some tweaks to the Pro class that will need addressing before we could ever consider running that formula at the Finals.
FMW is offline
Old 01-10-2012, 10:51 AM
  #16648
F N CUDA's Avatar
Are you saying you've seen my poorly set up Mini?
F N CUDA is offline
Old 01-10-2012, 11:34 AM
  #16649
I'm thinking of making the trip down from Norcal to run 1/12 scale. How many of you are going to run 1/12 scale? Will there be a class?
OutsideLine is offline
Old 01-10-2012, 02:44 PM
  #16650
minidriver's Avatar
Or the poor old M-06 that is wicked on carpet but deplorable on asphalt with same tires front and rear may now have a fighting chance on pavement! Seems that at least someone seems to think the car needs the assistance of different grip tires front versus rear, cuz that's the way Tamiya ships out the car from the factory in the box - low grip front tires, high grip rear tires.
minidriver is offline
