Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree824Likes
Old 05-02-2005, 10:51 AM
  #1606
SCML's Avatar
I'd like the same thing, but I've had no luck finding anything yet.
The old B tires are good when it's hot, A tires work when it's cold to cooler than hot, B2 doesn't work at any time, and the B3 might be nearly as good as B when it's hot, but should last longer.
That's what I've been told so far.
Mike
SCML is offline
Old 05-02-2005, 12:06 PM
  #1607
snopro31's Avatar
Trader Rating: 57 (100%+)
The info i got so far in my quest has been
Tamiya A act close to a CS22
Tamiya B act close to a CS36
Tamiya B3 act close to a CS27
I have no time on the tires to prove this for myself , but this is how i have been told the B2 tires i have not heard anything about , i was hopping some of these long time TCS guys would have lots of onroad experience with the tamiya tires and regular tires.
snopro31 is offline
Old 05-03-2005, 11:25 AM
  #1608
If you were to look from a racing standpoint.
Tamiya As are best for indoor carpet and low grip situations. Outdoors they can work if the pavement has no heat in it or the track is very cool or moist. They don't like to heat up if they do they get greasy.
Any Tamiya B works best outdoor.
Tamiya B - Offers good grip will easily blister under high heat situations usually past 130f track temp. They will work well in cool conditions.
Tamiya B2 - Are a thicker carcass can stand up to the heat more but can be harder to hook up especially under cooler conditions.
Tamiya B3 - Seem to hold up better than the Bs under higher heat. I have only ran them a few times last year. Evidently they are the replacement tire of choice.
As far as ratings.
I always compared the A's to CS27 although a friend has a durometer and says they can range anywhere from CS22 to CS27.
Any of the B's I don't know their rating. Usually I just use them and adjust inserts and rim holes accordingly. B's are hard to find, B2's can be harder to use and B3's are probably the best/newest choice.
My experience is with sedans. If you are talking Mini's or another class then things are different.
A-Ko is offline
Old 05-03-2005, 01:15 PM
  #1609
snopro31's Avatar
Thanks for all the tips and info .
snopro31 is offline
Old 05-03-2005, 08:43 PM
  #1610
No problem, hopefully it simplified your choices.
A-Ko is offline
Old 05-04-2005, 10:34 AM
  #1611
snopro31's Avatar
Hi yes it did thanks alot. now its baiscly only up to inserts LOL. But thats not so bad i dont think , do they have to be tamiya inserts in the US?
snopro31 is offline
Old 05-04-2005, 07:04 PM
  #1612
Kevin CBR's Avatar
Rule #2 from Tamiya web page:
Any manufacturer's electronic speed control, radio equipment, servo saver, antenna, antenna mount, pinion and spur gears, spur gear adapter, ball bearing, tire inserts are allowed.
Kevin CBR is offline
Old 05-04-2005, 09:53 PM
  #1613
snopro31's Avatar
Ok just asking here in canada we have to use tamiya inserts as well. This way i can be a little more ready for when i get to come to the US for a race.
snopro31 is offline
Old 05-09-2005, 06:21 PM
  #1614
DOTMAN is offline
Old 05-10-2005, 02:34 PM
  #1615
snopro31's Avatar
TA05R ? , if the TA05 is the car for the past champs race , does that mean there will be an R version out or will they be allowed to add bearings and threaded shocks all the normal stuff people need in a race car.
snopro31 is offline
Old 05-12-2005, 08:47 PM
  #1616
quantum's Avatar
Originally posted by gtypecanare
Looks like if you have plans to flying out, you got this weekend and I believe the following weekend April 30th, as the track will be closed until the Reedy Race. The next open practice sessions will be the weekend after the Reedy race,the day before the TCS Regional at Tamiya America
so, to be clear, the tamiya track usually has regular hours, except when special events occur... and in this case, they are closed from now until the reedy race may 28/29, and then closed until june 4th....
so when there aren't any special events, the track is open during the weekdays... is that correct?
quantum is offline
Old 05-12-2005, 08:50 PM
  #1617
Hebiki's Avatar
Trader Rating: 26 (100%+)
track is only open on saturdays. 10am to 4pm
Hebiki is offline
Old 05-12-2005, 08:53 PM
  #1618
Mr. Postman's Avatar
No.
Tamiya opens the track only on Saturdays, from 10:00am to 4:00pm. They normally open the gates around 9-ish, to let people start getting set up.
However, the week before the TCS National race (in August), they open the track all week (10am~4pm) all week long.
TC
CoBroRa/TAOB
Mr. Postman is offline
Old 05-16-2005, 09:14 AM
  #1619
The track will be open for practice as normal Sat. June 4th The gates will not open until 9AM so those showing up like it's a TCS event at Oh, dark 30 you will be wasting your time. Remember as far as that day it is a practice day as usual. Sunday it is a different story and you may want to get there early.
Also on Saturday and possibly Sunday bring your own tables as assuming there will be tables could very well be a mistake on your part.
corvin12xu is offline
Old 05-16-2005, 07:01 PM
  #1620
quantum's Avatar
wow, sounds like a big race with lots of racers.
what time should you expect the event to wrap up on sunday (after awards, etc.)?
quantum is offline
