Go Back  R/C Tech Forums > General Forums > Racing Forum
Tamiya Championship Series >
Like Tree821Likes
Old 03-26-2011, 03:09 PM
  #15541
414MPH's Avatar
Originally Posted by robk
I showed the battery to Fred Medel last year at the Nats. He Ok'd it.
Rob is correct again. Fred approved this type lipo in a hard case for F-104. I was there for the conversation.
Originally Posted by g12314
Another note, the side wings still need to be on the car for TCS events. I believe Marty brought this one up last year.
Why, yes Jimmy, you are correct. That is the word direct from Fred when I ran F-104 last year. He stated the electronics trays must be installed per the assembly instructions.
414MPH is offline
Old 03-26-2011, 07:57 PM
  #15542
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by xsracer
This is good to know,but didn't Tamiya just release a heavier rear battery brace as an option for added weight in order to get the rear traction to increase?IMHO,I'd rather go with a liter battery and add the weight where I see fit.I bought a battery of this size at RCX 2200 mh and 40c for $13.00 only it wasn't in a hard case.I'll try it in our UF1 series.
For high traction carpet with foam tires, the car goes faster the lighter it is. This is quite the opposite of rubber tire on asphalt, especially if there is not track prep like sugar water or VHT. The lower the traction, the more lead you should be stacking on your ride
robk is offline
Old 03-27-2011, 02:56 PM
  #15543
Now you tell me... I thought it was versa visa. . .
I must have sat too close to Marty, seems I share the same love for the F104.
A-Ko is offline
Old 03-27-2011, 08:13 PM
  #15544
robk's Avatar
There's your first mistake
I'm here all week, tip your waiters
robk is offline
Old 03-29-2011, 10:35 PM
  #15545
Default Must..read..more...often...
Tom Slick,where do I start the research for parts to convert my M05 to an M06?I'm gonna give this RWD a go at it.Thanks for your time Amigo.
Sorry I didn't read up sooner, Carlos mi hermano. Correcting papers and all. I got the idea of M06 from M05 conversion from Mark H. at TA. I ordered up from Speedtech the A, B, C, D and E parts trees for the M06. I also pulled down an instruction manual from Tamiya's website and went step by step.
If I had just strictly used plastic parts straight from the instructions, I would have spent about $80 on parts. I already had the aluminum steering gear on my M05--that was a direct swap. And, I already had a lot of fasteners needed uniquely for the M06. I did spring for the aluminum rear bulkheads, which added $35 to my cost. And, I did not have the unique rear hingepins with the ball studs integral to them for the lower rear shock mounting points--another $8.
Both cars use the same suspension arms, uprights, and gear trains. Also, I already had a set of aluminum full-size shocks--not the Mini-size ones--and such niceties as the hollow gear shafts, bearings for everything, and U-joints. So it helps if you have a lot of other Mini-series parts laying around. If not, buying the whole M06 Pro kit is a better deal, even if it doesn't come with aluminum shocks. And you'll still have to spend more for goodies like the aluminum bulkheads that don't come with the kit.
Tom Slick is offline
Old 03-29-2011, 10:41 PM
  #15546
F N CUDA's Avatar
Trader Rating: 34 (100%+)
That's what I was thinkin and you will still have an M05 as well as the M06 instead of an M05 in a basket.
F N CUDA is offline
Old 03-29-2011, 11:57 PM
  #15547
Kevin CBR's Avatar
I just said the heck with it and sold my M05 Pro and built up an X-EVO fwd mini.
Kevin CBR is offline
Old 04-01-2011, 08:04 AM
  #15548
Trader Rating: 129 (100%+)
Default TCS Regional Hall of Fame - April 1st 2011 Update
I was able to update the HOF table I created last year to include late 2010 and early 2011 results.
Still missing quite a few race results. If you have complete results or podium finishers for the following races, please let me know and I can add them to the summary table
Race # Approx. Race Date(s)
42 Oct-97
47-64 April 98- Nov 99
66 (GT2) Nov-99
68 Feb 00 (canceled?)
76, 77 Nov 00 - Mar 01
161 Mar-11
ewippler is offline
Old 04-06-2011, 09:23 PM
  #15549
Any chance the tamiya track is gonna be open this weekend?
MDRTales is offline
Old 04-06-2011, 10:15 PM
  #15550
42 Oct-97
66 (GT2) Nov-99
161 Mar-11
I should be @ 4 wins. Had one this year one last year and 2 long time ago.
A-Ko is offline
Old 04-07-2011, 04:46 AM
  #15551
Hi Jeff,
I think Tamiya USA transposed the result from Omaha '11 - I seem to remember you winning GT2 this year. It has you in 2nd. I can correct that if that was the case.
Erik
ewippler is offline
Old 04-15-2011, 05:33 PM
  #15552
414MPH's Avatar
Any insight, inside information, educated guesses or just plan dart board predictions on classes and their structure for NAF's?
Hello, Anyone.....
414MPH is offline
Old 04-17-2011, 09:45 AM
  #15553
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Hello, Anyone.....
Yes there will be finals
BP SHADOW is offline
Old 04-18-2011, 07:10 PM
  #15554
robk's Avatar
Hello, Anyone.....
+ YouTube Video
robk is offline
Old 04-18-2011, 09:15 PM
  #15555
Trader Rating: 39 (100%+)
+ YouTube Video
You heard it here first folks. Clubber Lang says his prediction is "Pain"
Jamie Hanson is offline
