Like Tree9Likes
Arm breakage
Old 11-07-2023, 08:22 AM
Trader Rating: 64 (100%+)
Default Arm breakage
Hey guys I have a question about front arms on 1/8 off-road
i have an issue with breaking my right front arm on my buggy ! I know the biggest problem is my driving skills but was wondering if anyone actually boils their nylon parts before using or is there any product that will possibly prolong life of my parts ?
Fast4Fun is offline
Old 11-07-2023, 01:37 PM
Zerodefect's Avatar
Nope. Might swap to a softer plastic arm in cold weather. Stiffer carbon in the summer.
Zerodefect is offline
Old 11-08-2023, 06:56 AM
Trader Rating: 33 (97%+)
Consider switching to a different brand of car, one of the main reasons I run brands with C-Hubs is improved durability around the arms. You don't have to share what brand of car you're running but I would be willing to bet it's a pivot ball if you're breaking frequently enough for this to be an issue.
There are some brands that offer universal arms that can be ran on the right or left side so you're not stuck with a bunch a left arms, ha!
billdelong is offline
Old 11-08-2023, 09:44 PM
Zerodefect's Avatar
It's a trade off. C hubs and it's knuckles are weaker than the upright on a pivotball car.
Old 11-09-2023, 04:48 AM
oldfool's Avatar
Nylon is “hygroscopic,” which means it absorbs moisture.
The greater the amount of absorbed water in the plastic, the more flexible (and thus, more durable) it becomes.
Boiling will only benefit nylon and nylon blends.
Other types of plastics will either be unaffected, or may warp or shrink.
https://www.rccaraction.com/how-to-b...astic-parts-x/
oldfool is offline
Old 11-09-2023, 05:25 AM
Roelof's Avatar
Most plastics take up water, problem today is that for sure plastics from competition models contains carbon and carbon will not be affected by water.
Roelof is online now
Old 11-09-2023, 07:54 AM
OffRoadJunkie's Avatar
This conversation reminds me of the Kyosho Triumph. Great car, but the front arms were practically designed to break. They sucked so bad! I ended up making my own out of fiberglass.
petersen114 likes this.
OffRoadJunkie is offline
Old 11-13-2023, 08:29 AM
petersen114's Avatar
I remember the Triumph. It was a good buggy and you’re correct about the arms. They didn’t have much to them, basically no structural support.
OffRoadJunkie likes this.
petersen114 is offline
Old 11-13-2023, 10:07 AM
Zerodefect's Avatar
Associated used to use really ugly white plastic. The primary reason to boil it was to try to dye it black. Best we ever got, was grayish.
Some said it helped durability. I doubt it.
Old 11-13-2023, 10:27 AM
I also didn't care for the belt drive gearbox. I was told the Pro-X gearbox bolted right onto the Triumph, but I never got a chance to try it.
Old 11-13-2023, 01:09 PM
oldfool's Avatar
Mine came out black. I liked the fluorescent yellow.
It was nylon and it did help durability, made it less brittle.
petersen114 and Zerodefect like this.
oldfool is offline
Old 11-14-2023, 08:29 AM
I have an HB and have never broken a front arm and I'm surely not the best driver wherever we race.
Goof likes this.
Fastfred1952 is offline
Old 11-16-2023, 01:35 PM
Not to mention the cover on the bottom of the chassis to view the belts would easily come off on landings.
Old 11-16-2023, 02:01 PM
It came off once and I never put it back on. That's when I put a chassis protector over the hole.
Old 11-23-2023, 02:01 PM
kruzracing169's Avatar
Brand?
kruzracing169 is offline
