Go Back  R/C Tech Forums > General Forums > Racing Forum
Voltmeter at tech station. >
Like Tree16Likes
Old 10-15-2023, 06:15 PM
  #31
all digital meters except vert high end are +or - one digit as a normal spec read the specs of a meter. So it could read 4.29 4.3 or 4.31 and still be in spec
fluke 77 VI Voltage DC Range 6.000 V Ė 1000 V Best accuracy Ī(0.3% + 1) Best resolution 0.1 mV
GMB Racing is offline
Old 10-15-2023, 08:17 PM
  #32
wingracer's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Zerodefect
There has to be a tolerance or grace range. And while we've generally been getting by with whatever nonsense voltage the RD chooses.......
4.3 would be the best cutoff voltage for DQ at all the tracks I've seen. Hundredths, should be ignored as insignificant.
4.2 and 4.27 are the same based on the tolerances of the meter. Do we see repeatable results down to hundredths? Sure. But it's sloppy.
I just dial in my charger to a few hairs over the RD's cutoff, then use his meter and infrared to check my battery before practice. (Keep in mind that your battery will cool, away from the charger)
A few general rules guidelines not just for this but pretty much all motorsports.
1. There is no tolerance on minimums and maximums. The room for error is above or below the line and how close you get to it is your choice and the risk you take.
2. Set values have tolerances. If something has to be 20mm, it should list a tolerance like +/- .1mm. So 20.1mm is good, 19.9mm is good. 20.11 or 19.89 is illegal.
DirkW and gigaplex like this.
wingracer is offline
Old 10-15-2023, 10:28 PM
  #33
gigaplex's Avatar
Nothing wrong with my meter.
It's saved my life, literally, about 11 times.
Saved your life by detecting extremely high voltages? Doesn't need to be 0.02V accurate to do that.
gigaplex is offline
Old 10-15-2023, 11:29 PM
  #34
Roelof's Avatar
In this case there is no lower limit needed.As an organizer running your own set of rules you can hold on to the roa/EFRA/FEMCA etc guide lines os set some own limits.
Roelof is offline
Old 10-17-2023, 07:35 AM
  #35
Zerodefect's Avatar
My point exactly.
Ya'll using an even lesser meter in tech. But it says "Fluke" on it. So its accepted by racers.
We make do. But it's amusing to me.
Zerodefect is offline
Old 10-21-2023, 08:06 AM
  #36
wingracer's Avatar
That's what I said, minimums and maximums do not have a tolerance, only set values have tolerance and this is not one of them.
gigaplex likes this.
Old 10-23-2023, 02:12 PM
  #37
Originally Posted by mrreet2001
Ichargers read out that far.
I have an iCharger. Setting the endpoint cutoff voltage is only to the hundredth.
gotheframe is offline
Old 10-24-2023, 12:53 PM
  #38
R/C Tech Elite Member
mrreet2001's Avatar
I answered your original question.
What charger are you using that is accurate to the thousandths?
... and still not relevant to my question ... ie the whole point of this thread.
What voltmeters are everyone using at the tech station? Anyone using one that reads 3 past the decimal at 4 and 8 volts? So like 4.22x or 8.44x?
Which is a simple question that didn't need discussion or whatever this fustercluck of a thread has been derailed into.
mrreet2001 is offline
Old 10-25-2023, 10:51 AM
  #39
Relevancy, whats the point of reading thousandths if you cant charge thousandths?
Or seeking advice on a forum when clearly you would have been better off with Google and simple logic?
Old 10-25-2023, 01:29 PM
  #40
Roelof's Avatar
I also know a guy who adjust his charger end voltage to match the 8.40v on the tech meter. As if the few mV gain can be noticed....
jiml likes this.
Roelof is offline
Old 10-25-2023, 01:54 PM
  #41
gigaplex's Avatar
You can press the stop button before it reaches the end point.
gigaplex is offline
Old 10-26-2023, 05:29 AM
  #42
mrreet2001's Avatar
Google isnít going to tell me what model of volt meters tracks are using or what digits they are looking at Ö what is wrong with you?
Old 10-26-2023, 07:31 AM
  #43
trilerian's Avatar
Trader Rating: 51 (100%+)
The guy that used to tech the big races at my local track used a Fluke 8808, which is a 5.5 digit meter. Which to simplify that, it reads a total of 5 digits when measuring a 2s lipo. A pass will be <= 8.4049. Why is that a pass, because Roar rules says 8.40 and on a 3.5 digit meter, 8.4049 will read 8.40, with some variance for accuracy.
If I were to tech a race, I would use a meter with at least 4.5 digit display, because most meters have an accuracy that is off a number of digits on the least significant number. Its one thing to be off a couple of thousandths, but arguments can arise if your meter is off a couple of hundredths.
If you are looking for a meter to suggest to your track, or pick up for yourself, I suggest the HP3478a, it has a 5.5 digit display (it is one of the meters on my bench). You can get them on ebay for <$150, they are old, but they are tanks and extremely accurate so long as the cal data hasn't been lost. But there are 2 things that need to be checked every so often. One is check the rifa caps for cracks, and if they have cracks replace them. The second is the onboard battery needs to be 3.00v or higher, that one requires some precautions to change as it holds the cal data.
mrreet2001 likes this.
trilerian is offline
Old 10-26-2023, 01:27 PM
  #44
I could, I'm just not going to. A thousandth of a charge isn't going to make a difference with errors on the track that costs tenths (or tens of tenths lol). Heck, pre-race I'd just burn it off with a lap or two warm up and then sitting, waiting my turn to start (with the cooling fan just whirring away like its not filled up with carpet fibers).
Google isn’t going to tell me what model of volt meters tracks are using or what digits they are looking at … what is wrong with you?
You missed the simple logic on that one. Bc google (or just head straight to amazon) is going to show you similar results for everyone else that typed "accurate voltmeter". Read some reviews, compare accuracy, look at prices. Oop... not going to buy one that costs $xxx. Narrow search by price, cause what track is actually going to spend three digits for a voltmeter. Which one has free shipping? Done, just like the person at the track that bought the voltmeter. You're way over thinking this, and its not going to matter (or be relevant).
Old 10-26-2023, 02:15 PM
  #45
mrreet2001's Avatar
Thanks for the input. But I was simply asking what tracks are using. Not some philosophical reasoning to a question I didnít ask. Itís not hard to say we have model xxx by zzz brand. You seemed to be making it overly complicated. I donít care what a bunch of paid Amazon reviews say.
