Go Back  R/C Tech Forums > General Forums > Racing Forum
Power station instead of Generator for RC racing >
Like Tree24Likes
Old 10-18-2023, 08:28 AM
  #61
DirkW's Avatar
I give up.
jiml and gigaplex like this.
DirkW is offline
Old 10-18-2023, 09:01 AM
  #62
Zerodefect's Avatar
Amp/hour is simply a statement: If you pour water out of this bucket at X amps, it'll be empty in X hours.
Wattage would be a real figure. Let's not go there.
Zerodefect is offline
Old 10-18-2023, 02:31 PM
  #63
gigaplex's Avatar
Wattage is just volts times amps. It has nothing to do with capacity. And it's not amp/hour, the / symbol explicitly means divide by. Amp hour is multiply by.
gigaplex is offline
Old 10-18-2023, 11:09 PM
  #64
Roelof's Avatar
Yes it is, but a more easy notation to calculate the available energy and the used energy because no matter what charging current the Wh value stays the same.
Roelof is offline
Old 10-19-2023, 01:41 AM
  #65
gigaplex's Avatar
Wh is not the same as wattage.
gigaplex is offline
Old 10-19-2023, 03:20 AM
  #66
Roelof's Avatar
Details, you think he was comparing Ah with W and I see he means Wh.
Roelof is offline
Old 10-19-2023, 06:47 AM
  #67
Current is coulombs per second, or in other words rate of transfer of charge. "Current-time" is just a bunch of coulombs. No inherent time factor .
Thank you Professor Einstein
jiml is offline
Old 10-19-2023, 06:49 AM
  #68
watt-hours and amp-hours are the same measurement, but on a different scale
jiml is offline
Old 10-19-2023, 06:51 AM
  #69
Dude, are you really still killing me for using a slash instead of a hyphen??? Next time we race together I'm putting your ass in the wall!
jiml is offline
Old 10-19-2023, 08:15 AM
  #70
Zerodefect's Avatar
I'll use slash marks, and you will read them.
/////// ---------- ///__//
Old 10-19-2023, 03:25 PM
  #71
gigaplex's Avatar
Well yes, when you use a symbol that means the complete opposite of what you're trying to portray I'll make note of it.
gigaplex is offline
Old 10-20-2023, 06:14 AM
  #72
It was grammatical, not mathematical
jiml is offline
Old 03-03-2024, 04:20 AM
  #73
strodedawg's Avatar
Trader Rating: 85 (100%+)
After reading this thread i have some questions but here is what is the situation at the track i am dealing with:
1- obviously no power at the track so I need a power source
2- generator is not in the plans right now
my set up:
electric 5th scale racing
2x 6s 7600 mah packs (so 15,200 mah) per run
capaciity needed if i run in practice, quals and mains (assume 6 runs max) so i would need a total of 91,200 mah
charging @7.6A per pack, 15.2A total
this is my charger both AC/DC
https://www.rcjuice.com/chargers-acc...e-charger.html
i understand that that total capacity might not reflect what i actually need as we do not run our lipos to zero capacity
can a car battery supply that much power for a full day? is there a power bank that can handle that much charging?
any help would be appreciated
thank you
strodedawg is offline
Old 03-03-2024, 06:33 AM
  #74
Roelof's Avatar
6s = 25.2v -> x 15.2Ah = 383wh
On a 12v battery -> 383 / 12 = 32Ah that is about a one time charge on a small car battery, you do need a huge battery like a 100Ah for getting 3 runs out of it....
Roelof is offline
Old 03-03-2024, 06:45 AM
  #75
strodedawg's Avatar
thank you very much for the reply. is that for charging a total of 12 packs? 2 6s @ 7.6a? is this a standard car battery or a deep cycle like I have been reading about? seen some 150ah ones out there
