Go Back  R/C Tech Forums > General Forums > Racing Forum
MUST HAVE upgrades? >
MUST HAVE upgrades?
Like Tree4Likes
  • 1 Post By jon003
  • 1 Post By killer rock
  • 1 Post By jgil089
  • 1 Post By Roelof
MUST HAVE upgrades?
Old 05-03-2019, 09:16 AM
BugleBoy10's Avatar
Default MUST HAVE upgrades?
Up until now, I have only bought used cars from seasoned racers. Of course, those usually come already built, upgraded, and mostly set up. Now Iím buying a kit (B6.1 Factory Lite), and want to know what you consider to be the MINIMUM NECESSARY upgrades to be competitive and durable on the track. If it matters, this will be for stock 17.5 class mostly on dirt and clay tracks, and I plan to swap the old ESC/servo/rx along with a brand new motor.
Also, if there are any doís and doníts while building it, or advice on how to interpret setup sheets, Iím all ears for that too.
BugleBoy10 is offline
Old 05-03-2019, 06:18 PM
Most of your current, modern kits are ready to kick butt out of the box. Save your upgrades for when you have an idea of what you want.
Do read the manual the whole way through before you start.
Do take your time.
Don't rush. Save your racing for the track.
Don't force anything. If something isn't fitting well, there's probably a reason.
Do keep a small metric ruler or calipers on hand. Do a quick visual check before inserting any screws/nuts/etc to make sure you're using the right size.
Setup sheets are a good place to start, but every track is different. Ask some of the fast locals with the same/similar car what they use.
BugleBoy10 likes this.
jon003 is offline
Old 05-03-2019, 10:49 PM
Aluminum servo horn.
faqcya is offline
Old 05-03-2019, 11:59 PM
Location: northern Indiana southern Michigan all depends on the day.
I would only look at durability issues, till I gotta a good handle on the car. Look through the b6.1 form for the durability issues.
Team Associated B6.1 & B6.1D thread
Don't waste money an so called speed parts.
killer rock is offline
Old 05-07-2019, 03:46 AM
Check through the thread for the particular car to see whats breaking. I suspect nothing will break in 17.5T. I was told when i bought my kyosho lazer that they break shock towers and they do in mod, but I haven't broken a single one in 2 years in 17.5T blinky. Alloy servo horn could be useful but I haven't broken the kyosho kit ones yet.
The only thing I would look at would be springs for tuning at the track if you don't have some that will fit already, and then see if anything breaks.
jgil089 is offline
Old 07-14-2019, 11:15 AM
BugleBoy10's Avatar
Thanks for all your advice. I built the kit with no upgrades except for half of the screws which I already had the sizes in stainless. The wing mount keeps tweaking, so I will probably get an aluminum one, but everything else is working great.
Jon003, your caliper suggestion was useful already too! I went back to a car I bought used last year and pulled every screw to measure and check against the manual. Obviously some people just put anything they have in there and forget about it. Luckily, I had almost all the right sizes to swap out.
Old 07-14-2019, 11:27 AM
Roelof's Avatar
The only needed upgrades are the ones that you think are worth to you as an upgrade or improvement on performance of lifespan.
Most of the time there is nothing wrong with a box stock competition car
Most of the time you have more gain with a selection of different tires and gears when focusing on racing.
Roelof is offline
