Go Back  R/C Tech Forums > General Forums > Racing Forum
How many batteries for raceday? >
Like Tree4Likes
Old 02-13-2019, 09:25 AM
Default How many batteries for raceday?
About to run in my first on-road TC race next weekend. Am Curious about how many batteries should I have for a typical raceday?
aERonAUtical96 is offline
Old 02-13-2019, 10:11 AM
the rc guy's Avatar
2 per car or rc. are you going to practice with race packs?add up
the rc guy is offline
Old 02-13-2019, 10:24 AM
Billy Kelly's Avatar
I usually have 2. Sometimes a third if I know I can get a lot of practice time
Billy Kelly is offline
Old 02-13-2019, 03:49 PM
the rc guy's Avatar
2 replys say the same thing..!
Old 02-13-2019, 03:58 PM
2 is the answer then Thanks.
Old 02-13-2019, 05:51 PM
the rc guy's Avatar
2 race packs 1 for practice..thats 3
Old 02-13-2019, 08:31 PM
gigaplex's Avatar
I use 1 per car.
phatboislim likes this.
gigaplex is offline
Old 02-14-2019, 07:37 AM
one per car... re-peak between rounds... LIPO do not have the issues nicad's did.
no memory.. no loss of speed/power between charges... no charge only once a week..
the "NUTS" days are over with batteries.
skater-deez1 and jgil089 like this.
chuck_thehammer is offline
Old 02-14-2019, 10:36 AM
Depends on your charger - if it can charge at 10 amps or more, 1 battery. If it charges at less, 2 batteries. I suggest you time how long it takes to charge from storage voltage and that will help you decide. My I-Charger will discharge and re-charge a 6000 mah battery in a bit over 20 minutes.
belewis01 is online now
Old 02-14-2019, 03:55 PM
my SC5M truck.. 10.5 motor.... I use 1,200 to 1,500 mah for a 5 minute race... takes my old lipo charger at 5 amps.. 15-16 minutes to recharge..
I never discharge my battery...
Old 02-14-2019, 11:45 PM
I run 2 cars and have 2 batteries and 2 chargers. Both are basically the spec of the SkyRC s60, but I charge at 5amps/1C anyway and have no issues. Had 1 charger but found that it could be tight depending on the gap between races. My son has started racing this year, I think 2 chargers and 3 batteries will be fine.
As far as practice/race packs go, here a race day is 3 - 4 races per class per month so 40ish cycles per year, plus practice days. If I used separate packs for practice and racing they would barely get used. Unless you're chasing 10ths or can have loads of track time, I would save your money and buy a charger with a channel per car and a single battery per car.
chuck_thehammer likes this.
jgil089 is offline
Old 02-19-2019, 01:15 PM
like previously mentioned, if you can charge at 10A or more, 2.
Now that I can, all I need is 2. :-)
Evoking1230 is offline
Old 02-19-2019, 06:02 PM
I have 2 packs and alternate them just because I can, but a 6 minute run uses about 1800 for my 21.5 spec car, and recharges in 5:30 at a 4c rate of 24a so I could easily use just 1.
anthonyscardina is offline
Old 02-21-2019, 02:25 PM
SuperDave417's Avatar
I'm curious to know what the average life span you are getting with packs you're charging at 10Amps? That is way too much for these batteries. I never charge mine over 5.0 amps. These batteries (LiPo) do not react as old batteries did. It doesn't matter how many amps you throw at it. It's only going to put out X amount of power and capacity. No matter how hard you try to overcharge them.
SuperDave417 is offline
Old 02-21-2019, 02:38 PM
Agilbert's Avatar
Lipo batteries arent what they used to be. now we are balancing each charge and one cell isnt getting abused like when not balanced. i charge at 25 amps on any shorty lipo and they dont even get above room temp. what i dont understand is we can pull 100's of amps at a time, but arent supposed to add that fast? never had an issue. same batteries for over a year and IR is still great
Agilbert is offline
