Go Back  R/C Tech Forums > General Forums > Racing Forum
Electronics issues. Please help. >
Like Tree3Likes
  • 1 Post By OverGeared
  • 1 Post By the rc guy
  • 1 Post By vwjuice
Old 12-21-2018, 09:23 PM
vwjuice's Avatar
Default Electronics issues. Please help.
Iíve been running Savox servoís and Hobbywing justock escís with a Sanwa MX-V radio system. I upgraded to a Hobbywing XR 10 pro in one buggy and an Rcconcept SC10R in the other buggy. Now both buggies have constant glitching problems. I even had a few runaways in practice tonight.
I installed a glitch buster in each car and they helped but the issues were still there. Couldnít race due to constant lose of steering or esc function.
Im trying to figure out if I need to upgrade to different radio or different servos or what?
​​​​​​​Thanks in advance for any help.
vwjuice is offline
Old 12-21-2018, 10:17 PM
1/8 IC Fan's Avatar
Trader Rating: 91 (100%+)
Thats weird. My son has used the MXV with the XR10 no issues, that is with the RX371W. What voltage are the servos rated for as the BEC is adjustable, not sure if that plays into effect.
1/8 IC Fan is offline
Old 12-21-2018, 10:23 PM
vwjuice's Avatar
the servos are rated for 4.8 or 6v. Itís odd that both are having these issues now. Theyíre just the basic savox 1251mg
vwjuice is offline
Old 12-21-2018, 11:51 PM
1/8 IC Fan's Avatar
Well the XR10 can supply 6-7.4V. So im not sure, if it may be set to 7.4. You need to check its programming. To ensure you are supplying the voltage required.
Old 12-22-2018, 12:05 AM
vwjuice's Avatar
i just checked and it is set to 7.4v already. This is going to be very annoying to figure this out.
vwjuice is offline
Old 12-22-2018, 03:23 AM
OverGeared's Avatar
Trader Rating: 15 (100%+)
If you have a different brand servo that is lying around just try to install it in and test if that eliminates the issue (even a normal cheap one will do).
You might want to check out the antenna connection of the receiver as well.
This note however is copied from the AMain Hobbies site under each and every Savox servo description.
"*NOTE: Certain combinations of receiver and ESC have been found to cause "Brown Out" issues when combined with Savox servos. An external BEC, or BEC stabilizing receiver capacitor may be needed for efficient, glitch free operation in low voltage electric applications."
1/8 IC Fan likes this.
OverGeared is offline
Old 12-22-2018, 06:38 AM
Trader Rating: 190 (100%+)
Have you tried to lower the voltage to the receiver as you said the servos operate up to 6 volts and your esc is giving them 7.4 volts
Troubles Dad is offline
Old 12-22-2018, 08:57 AM
vwjuice's Avatar
you know, I never even noticed that. 😱
that describes my problem. Iíll have to get an external esc and try it.
vwjuice is offline
Old 12-22-2018, 08:58 AM
vwjuice's Avatar
i did that this morning and it wasnít as bad it still happens. Iíll look at an external bec and go from there.
vwjuice is offline
Old 12-22-2018, 11:39 AM
if it was me I would start over set up the esc for 6 volts, bind the rx to the radio, calibrate the esc then set end points, checking that they are restored to factory before binding, if that does not work change the rx then the servo
Old 12-22-2018, 11:44 AM
vwjuice's Avatar
yeah I think I will do that. Canít hurt to start over.
vwjuice is offline
Old 12-22-2018, 12:12 PM
the rc guy's Avatar
Why is this same post in 2 separate categories or subtopics.. why start over ...its a voltage supply issue ..
the rc guy is offline
Old 12-22-2018, 01:57 PM
did he miss something when he was setting this car up? As I would think giving a servo 7.4 volts would not be good for it especially when it was rated at 6 volts, as this past summer I had throttle servo issues in my mbx7tr, the first one locked up, the second had NO travel for brakes and the other went super slow, I first thought low rx battery, but after 5 minutes it would act up again, it was the rx that had went bad after changing the servo tray and battery and I even rebound it and checked end points on the bench and running on the box, so by starting over it would help to isolate the issue as could even be the battery not fully charged as it's really hard to diagnose on the internet, so change one thing at a time and you will find the problem as could even be the rx wire not pushed all the way into the receiver
Old 12-22-2018, 02:48 PM
vwjuice's Avatar
I rebound the receivers in both cars and installed new glitch busters. Recalibrated both escís and changed the setting down to 6.0v and these all fixed the problem. Now they are working like normal.
Thanks everyone for the help.
Troubles Dad likes this.
vwjuice is offline
Old 12-22-2018, 02:49 PM
vwjuice's Avatar
i posted in two groups that way I can get as much help as I could. Itís hard to diagnose things over the internet, so any little advantage helps. I know I myself donít look thru the electronics forum very often. I figured thereís probably people that look thru one forum more than the other.
vwjuice is offline
