NITRO ENGINE SECTION - BOOOOOOOO!!!!
They should also have different section for Buggies and truggies.
Looking through 20,30, pages to find a specific buggy is time consuming. Looked yesterday for Caster Racing nitro buggy(ZX-1???), but couldnt find the correct one.
Should be-Nitro Offroad>>1/8 Scale Buggies
-Nitro Offroad>>1/8 Scale Truggies
-Nitro Offroad>>1/10 2WD Trucks
so on and so forth.
so on and so forth.
Isn't that why there's a Search function, and why you can Subscribe to threads?
i had a request for a nitro engine forum
so i moved the one that was hidden to open view....
i can just as easly delete it and you can all start over.
i will not make a on road and off road forum, because people will cross post, put things in the wrong place. and it will be a large headache...
so here is the choice,
delete what is there, and post in the onroad and off road nitro forum. or keep what you have and make the best of it....
you guys are never happy, i really dont kow why you come here
All that needs to be done is create the same kind of sub-forum in the offroad section. Then move the current thread back where it was and move all the offroad engine threads into the new sub-forum in the offroad section.
As for having the time to do it, create the sub forums, give me the ability to do the moving of threads and I will happily do it myself. Then everything is as it should be and very few if anyone would be upset.
Most of the requests I saw were to have a sub-forum just like the onroad section. I don't recall seeing anyone request a whole new, all lumped together thread but hey, maybe I missed it.
And you guys never really listen. You offer only two choices when the perfect third choice is left unmentioned. The sub-forum in the onroad section was perfect. There was no problem with cross posting because the offroad guys never went in there. Hell, most of them didn't even know it existed.
the model of motor may be different, but the basics of break in, tuning, maintenance are all the same correct??
i can make what you want, but that is not what was asked i looked at the forum today, there have been less than 25 threads used since yesterday....and it was worse when it was hidden away....
i tried to make a forum that could be seen and used, not hidden from view so only a select few knew where it was..
Matt,
I like the idea of having a separate nitro engine sub forum for both the on road and off road nitro. No doubt they are both nitro engines but the target audience are different. Why not give it a try? If is doesn't work out you can always merge the two nitro engine sub forum into one like the current one.
Thanks.
Thanks.
unless he changes it that's the way is going to stay
Matt,
Thanks.
Thanks.
give me a couple days to get it done....
we are not opposed to change but i was asked to do what was done. guys need to be more respectful when asking for a change.
