Go Back  R/C Tech Forums > General Forums > R/C Tech Site Forum
how to set ratio...for track >
Old 02-22-2007, 02:47 AM
terabyte's Avatar
Trader Rating: 4 (83%+)
Default how to set ratio...for track
hello anybody know?
pls help me how to setting
terabyte is offline
Old 02-22-2007, 07:07 PM
BuggyKing's Avatar
Trader Rating: 17 (100%+)
What radio are you running. My M8 I run my end points and a little throttle trim and you can adjust your steering trim accordingly.
BuggyKing is offline
Old 02-23-2007, 11:11 PM
Trader Rating: 49 (95%+)
your gear raTio im assuming is what you meant? if so, easiest way is to ask what others are running and adjust from there. i run 4200's so run time for 5mins isnt an issue, im running brushless so i just gear to what runs at a good temp and i can tailor the gearing to my driving style, ie running a taller gear to keep from blowing the tires coming off the corners etc
loopedout is offline
