Strange behavior under firefox
Since, Sunday the layout has been altered. No images, no banners etc
On IE everything is ok!!! Has anything changed ? If not, any ideas what I have enabled/disabled? Thank you Nick |
I generally use Firefox to browse R/C Tech, but haven't seen anything change recently.
You might want to try clearing your Temp files, see if that fixes it. That is unless Firefox has an option to disable images? Might want to look through the tools and options. |
Yes there is disable images option but it wasn't enabled. But I found it!!!
For some reason rctech was on block images list under Content Load Images Exceptions Thank sfor the help |
Glad you figured it out. Hopefully if someone else runs accross the same problem they'll find the solution here. :)
