Go Back  R/C Tech Forums > General Forums > R/C Tech Site Forum
Am I using this Forum Correctly? >
Like Tree1Likes
  • 1 Post By 1/8 IC Fan
Old 03-20-2019, 03:33 AM
Code's Avatar
Post Am I using this Forum Correctly?
Hi, I have put up couple of questions over the last week or so.
No replies yet. Am I doing something wrong? Can people see my questions?
Code is offline
Old 03-20-2019, 03:44 AM
Billy Kelly's Avatar
Sometimes it takes a little time for post to be seen.
Billy Kelly is online now
Old 03-20-2019, 03:52 AM
1/8 IC Fan's Avatar
Trader Rating: 95 (100%+)
Well, also take into account if you post something related to a vehicle or item that the possibility exists that no one else may have that vehicle or component! So you may be the first one posting on that item.
Secondly, if you post in the threads on certain vehicles and components you are inquiring about, you will much sooner get an answer, case in point your Traxxas cleaning of the Diff Inquiry.
So, it take a bit to get used to the RCtech Site and navigating it, but id say 95% of the time the search function will lead you to a thread related to your inquiries.
Welcome aboard.
Billy Kelly likes this.
1/8 IC Fan is offline
Old 03-20-2019, 04:39 AM
Roelof's Avatar
The only question I can see:
https://www.rctech.net/forum/electri...l#post15416330
Sometimes first posts need to be aproved by an admin before they are shown to the public.
And keep in mind that it can take some time before you get reactions.
Roelof is offline
Old 03-20-2019, 04:52 AM
1/8 IC Fan's Avatar
Roelof he also has this one: HSP Buggy BT9.5 EP 4WD Brushless 1/8
Old 03-20-2019, 08:56 AM
the rc guy's Avatar
yes you are using the forum correct.as others have said it does take time 4 answers.I personally only see the what gear diff oils should I use and this 1 the missing 3rd post on your info under your avitar shows 3 I only see 2 .use stock or manual recommended oils.
the rc guy is offline
Old 07-18-2019, 12:45 AM
Maybe its your question
quentinj is offline
Old 09-12-2019, 12:54 AM
IMSupercar's Avatar
Can someone give a little help?
IMSupercar is offline
Old 09-12-2019, 04:33 AM
Iíll try
Old 09-12-2019, 08:55 AM
the rc guy's Avatar
help with what ?.
Old 10-17-2019, 11:12 PM
Default Am I using this Forum Correctly
i tried last night with info, i didnt like the result so i put it back like this till i can have a day off and it will be my first thing that day
CarolDurse is offline
Old 11-26-2019, 11:16 PM
yes, you are using the forum in right manner. It's just that the volume of posts is too high and it takes a little time before someone notices a post. Also, the topic you chose to wrote about might not be so popular. Stay patient and try again with a different title and post content
stevejonas is offline
